Scrounger said:Yes my wife thinks I'm extremely sad and need to take up something more satisfying like gardening!!
Dan
Our wives would get on well!
Dan
Scrounger said:So insurance quote is done and Hasting is coming out cheapest at £493 but I've never used them before so a little sceptical. Admiral are in at £656. I was insured with them on my current car for the first year at not much less however they sky rocketed in the second year.
I'll give my current insurer, Highway through Chris Knott, a call and see what they quote.
Dan
Scrounger said:I also didn’t win they tyre lottery and have got Pirelli’s![]()
Neil Chadwick said:Couple of things I have noticed which are very different to the 981 are that the water / oil temp numbers increase unrealistically fast. On the 981 it used to take about 10 miles/25 mins for the water / oil temp to be in the 90's whereas on my GTS they get up into the 70's/80's after about 10 mins and are not in line with the blue graphic, which indicates a lower temp. I'm taking it back to the dealer for this to be checked as it doesn't seem right to me. Temps are totally stable once they reach operating temperature.
Possibly interestingly my PDK GTS4.0 takes a lot longer to come up to full working oil temperature than my previous manual GTS4.0. About twice as long in fact, and this is even if I use the devil‘s gearbox in manual mode keeping the revs higher than the normal auto setting would doTwinfan said:Neil Chadwick said:Couple of things I have noticed which are very different to the 981 are that the water / oil temp numbers increase unrealistically fast. On the 981 it used to take about 10 miles/25 mins for the water / oil temp to be in the 90's whereas on my GTS they get up into the 70's/80's after about 10 mins and are not in line with the blue graphic, which indicates a lower temp. I'm taking it back to the dealer for this to be checked as it doesn't seem right to me. Temps are totally stable once they reach operating temperature.
The new 4.0 heats up quicker and runs hotter than the 981. Totally normal.
Apologies as off topic, but Graham really interested in your move from a manual to PDK GTS 4.0 as I'm thinking of doing the same. If you don't mind me asking what was your situation/motivation for changing and what are your thoughts on the switch from manual to PDK? Thanks KerryWollemi said:Possibly interestingly my PDK GTS4.0 takes a lot longer to come up to full working oil temperature than my previous manual GTS4.0. About twice as long in fact, and this is even if I use the devil‘s gearbox in manual mode keeping the revs higher than the normal auto setting would doTwinfan said:Neil Chadwick said:Couple of things I have noticed which are very different to the 981 are that the water / oil temp numbers increase unrealistically fast. On the 981 it used to take about 10 miles/25 mins for the water / oil temp to be in the 90's whereas on my GTS they get up into the 70's/80's after about 10 mins and are not in line with the blue graphic, which indicates a lower temp. I'm taking it back to the dealer for this to be checked as it doesn't seem right to me. Temps are totally stable once they reach operating temperature.
I would be interested too - still can’t quite make my mind up as to which one to go for!Tetris Keyring said:Apologies as off topic, but Graham really interested in your move from a manual to PDK GTS 4.0 as I'm thinking of doing the same. If you don't mind me asking what was your situation/motivation for changing and what are your thoughts on the switch from manual to PDK? Thanks KerryWollemi said:Possibly interestingly my PDK GTS4.0 takes a lot longer to come up to full working oil temperature than my previous manual GTS4.0. About twice as long in fact, and this is even if I use the devil‘s gearbox in manual mode keeping the revs higher than the normal auto setting would doTwinfan said:Neil Chadwick said:Couple of things I have noticed which are very different to the 981 are that the water / oil temp numbers increase unrealistically fast. On the 981 it used to take about 10 miles/25 mins for the water / oil temp to be in the 90's whereas on my GTS they get up into the 70's/80's after about 10 mins and are not in line with the blue graphic, which indicates a lower temp. I'm taking it back to the dealer for this to be checked as it doesn't seem right to me. Temps are totally stable once they reach operating temperature.
