Re the previous photo of the non-N rated PS4S.
For convenience, I have re-posted the photo of the PS4S N0 tyres on my 718.
Brian
Brian
BJ Innes said:It will be interesting to see the differences between the 981 and the 718 in the suspension department. Already apparent is a greater degree of alignment adjustment on the 718 compared to the 981 at both the front and rear. Currently I'm getting -1.27" degrees of negative camber on the front axles of my 718. My car has the 20mm lower PASM which may contribute to this extra negative adjustment. For interest, I'll also be reporting back on the maximum attainable negative camber on the rear axle during the geo setting. Be interesting to see if a wider range of negative camber adjustment is also available at the rear.
Twinfan said:Interesting stuff Ralph. You have an S, correct? Your numbers are more similar to the S Brian has observed than my GTS. I'd be surprised if GTSs had more adjustment so it's probably just car by car variation.
Given the similarity of parts you've observed via PET I'm guessing you wouldn't expect the 718 to have more adjustment than a 981?
