Big Dave
Fen
Where did you get your 3mm bit from regarding the torsions.??
I have been told that each spline change [ both inner + outer ] is equivalent to 6.5 mm..
Ive just done my S2 .. i dropped it by 4 splines but it didnt seem enough ,i started out with a ride height of 350mm , from floor to rear wheel arch.. so im re-doing it tomorrow ,, another 2 splines...
I also had aprox 12mm to play with on the excentrics....as they were set in the middle....
Ive also found out that you need to let the car "settle" back down on its bars for a while to get the correct height... My car has been off its wheels for over a week now , so some settling is needed...
The rear beam is now nice + easy to remove.. as everything is now coated in a film of copper grease...
It took me aprox 30 mins to remove almost all the bolts tonight in readiness to do "the job" tomorrow.
The first time i did it it took me about 3 hrs as there were a few solid bolts etc...+ there was also a bit of alloy corrosion between the different steels etc....
Ps Frogisland is a good m8 of mine + weve been "trading experiences" for a while + know just how much he lowered his car by....His 968 CS IS possobly one of THE best out there + i can testify that it DOES handle extremely well,, now ....
Tony ..
Your KLA top mounts ?? how have you found them..??
Are they any harsher than standard.??
Any more noise .??
Tony ..
Any more noise .??
