Quite so Dave. I assume that the problem is associated with failure of the electronic activation of the mount rather than actual failure of the mount itself, which would indicate that the mount’s electro-mechanicals aren’t robust enough to cope with the “spirited driving” for which they’re designed. A contradiction in terms?Twinfan said:Motorhead said:It’s just a jazzed-up hydro-mount which for the majority of your driving won’t be activated Dave, so I can’t really see the LWF connection myself, and there appear to be regular failures with the standard DMF sufficient to indicate that it’s a generic problem which is independent of engine if it’s still happening on the F-4 and F-6 turbo-engine cars too.
Jeff
Agreed Jeff. I think you could possibly argue a little more vibration may be present with the LWFW, not that I've noticed any whatsoever, but I would counter that by saying regular track use with the car bouncing off the 8k rev limit all the time would be worse!
Jeff
