Not sure what mods you can do in your series? Can you go up to larger calipers and rotors? Are they solid rotors or other? What pads are you using?
I am getting some full floating front rotors with slotting next week. I found that while the cross drilled ones from the 965 really help in dissipating
the gases which in turn makes the long brake travel abate somewhat, they crack too easily. So I'm trying these. They will be lighter as well which is
a good thing too.
I found that the factory 40% LSD wouldn't stand up to trackwork and needed rebuilding pretty regularly. See how you go, otherwise there are options.
a good thing too.
