Something i have been working on!
- Thread starter MarkK
MarkK
Well-known member
MarkK
Well-known member
DivineE
I know that feeling you mean though. I got straight out of a 996GT3 RS and into my old car at Silverstone. It felt like a lounge sofa even on KW V3's compared to the hardcore RS
Diver944
ORIGINAL: DivineE
I would still really like to go out in that car.
Don't do it Ben, it will warp your mind (and empty your wallet). Roadgoing 944's feel like big wallowy armchairs in comparison [
DivineE
ORIGINAL: Diver944
ORIGINAL: DivineE
Don't do it Ben, it will warp your mind (and empty your wallet). Roadgoing 944's feel like big wallowy armchairs in comparison []
I meant the other one actually. After the 1100kg TVR on after market coil overs I need no further persuasion about the benefits of a stiff light car. I will probably go for the GAZ coil overs Mark uses but with my 16" wheels on fat doughnuts and normal road weight to soften it up a bit
Diver944
ORIGINAL: 333pg333
I tried to load a pic of the alternative Alternator and bracket but it was too large.
Here's a smaller one. Hope Brian is okay with me posting it here (I'm sure he is)
DivineE
ORIGINAL: 333pg333
Ben, what is the focus of your car? Street cruiser with occasional visits to the track, or more track focussed?
It will be my only car and primarily a mile munching road car but having felt how soft KW's are on the track I think for the odd time it does get to a circuit it would really annoy me. I would like to have something many times stiffer so I can really chase down cars and live with a bit of a harsher ride on the road. I'm thinking 800 front springs and 600 rear (seems to be what everyone suggests for the track) can anyone tell me if its unbearable on the road or dangerous on motorways that stiff? My Z4m was too stiff and that was lethal on bumpy roads!
sawood12
DivineE
ORIGINAL: sawood12
KW's soft? Compliant yes. Soft, no way. There is a difference. I had stock ARB's on stock but refreshed bushes and the dampers set on about 3/4 and the body roll was almost non-existant as was braking dive and rear squat under acceleration, so pretty stiff, especially for a road setup, but rides the bumps great - just what suspension is supposed to do. Granted the v3's is a street setup so for a more dedicated track car you'd want suspension that is 2 to 3 times the spring stiffness, but that's not comparing apples with apples.
I'm sure it feels great on the road, my golf did on KW's but all I can say is at Silverstone getting out of a gt3 rs into the 944 on KW's was literally like getting into a speed boat! I couldn't believe how soft it felt! It's just really put me off them. As you say though its an extreme circumstance and I will have to have suspension 2-3times too stiff for the majority of the time to make it feel as tight as a gt3 on the track.
sawood12
MarkK
Well-known member
All the uprated clutch parts arrived.. the final bit yesterday,the car is stripped and ready so hopefully it will all go back together without too much hassle on Monday,really curious to see the change it it will make to the car and its ability to pull away a bit more sharply..[8|]
u63af
999 201 215 00 Needle sleeve x 2
951 116 133 00 Operating shaft x 1
The guide sleeve that the release bearing sits on as well can sometimes also get quite a ramp in it, 016 141 181 is the part number for that.
Hope this is of some help,
Alasdair
