Sunroof
- Thread starter sib8292
In the absence of anybody more knowledgeable answering this one, I think that the micro-switches and the associated cam are next to the sunroof motor located in the 'wall' of the boot. I haven't yet explored the workings of my sunroof yet, but it is on my (ever-growing) list of 'jobs to do' on my S2. A good guide to the workings of the sunroof can be found at http://www.clarks-garage.com and specifically in the following document: http://www.clarks-garage.com/pdf-manual/body-03.pdf.
HTH.
Graham
ORIGINAL: pikey7
I must admit, I've not done it either, but I thought the microswitch was under the roof panel next to the windscreen. I think that's what the little plastic tab on the suroof panel presses on.
Mike, that is just one of them on the 944, don't know if the UK market '84 924 is the same but should be easy enough to tell. Then there are another 3 of them back on the drive motor.
The sunroof is an overcomplicated nightmare that usually gives every owner headaches.
Harriet
As the others have said, there is a micro switch between the sunvisors. The triangular shaped tab.
I think yours will be different to mine (pic of the motor in boot) '89 S2 two micro switches above motor.
Earlier 944s were different, micro switch above and below. So most likely the same as your 924.
andymarsden1
When you go over 10mph, if the sunfoof hasn't been locked down (i.e.the sliders havent gone back into the sunroof so you can still push it open) the sliders go back into the roof and stop, leaving the sunroof closed but the sliders back in the sunroof so you can't push it open.
Anyway at 10 mph regardless of what stage the sunroof is in open, closed, tilted, whatever it tilts up to maximum and then slips on the nylon gears making a horible sound that you can't stop unless you drop back below 10mph.
So booked the car in to have it sorted, because i wouldnt know where to start, but i cant drive the car without stripping the nylon gears down to nothing. So i've just taken the relays out of the motor with the sunroof closed and locked, and i can pop them in quickly if i need to take the roof off.
Car is booked in next week to have it done properly, because i hate having anything wrong with my car. [
Thanks, again
Andy
+Elenor
andymarsden1
ORIGINAL: IceShark
.......The sunroof is an overcomplicated nightmare that usually gives every owner headaches.
I agree. Beaky seems to ignore the ignition switch in position I or II criteria and retracts the legs completely which ever. To lock the roof I have to lean into the back and watch until the pin on the leg crests the incline and then take my finger off the switch. It's not very cool, and I tend to leave the roof locked unless I press the wrong button by mistake when adjusting the wing mirrors.
ORIGINAL: 944Turbo
John, Sounds like your front microswitch has been bypassed,
Tony
Or he could have partial failure of the main sunroof relay, the one that is so expensive - around $120 USD.
Those usually don't totally fail, they fail in steps and not being able to distinguish the ignition key position is step one. Borrow a fellow owner's working relay and see if that resolves the problem. But be aware that there are at least two different versions of the relay for different year cars so check the relay base and make sure they have the same pin outs. The early ones are missing one of the legs, I forget if it is leg A or 1, whatever, they are missing a leg.
ORIGINAL: IceShark
I have every confidence that, as it is expensive, that will be the fault. [
As I don't use the sunroof, I think I may stay happy in my ignorance as to whether the relay is going or not. If we prove it to be a faulty relay I wont be able to resist replacing it.
If you cant then take the switch outand check it works, and theres power to the switch.
If it does work then,
Take the trim off at the rear of the sunroof, there you will find two gears that work the arms.
Check that they have not been stripped or damaged.
if they are ok, then you will have the check the microswitches at the sunroof motor in the boot, I find that if i havent used mine for a while, like all winter, they sometimes stick.
If none of that works, then I'm a bit stuck without anything further to go on.
TTM
Well-known member
ORIGINAL: dave993cars
when I put it back in place the two rear levers don't move
Sorry if I'm stating the obvious, but ignition must be in first position otherwise the levers won't move forward to block the roof panel.
dave993cars
You people are wonderful, take a pat on the back, the micro switch had a bad connection, once cleaned the sunroof works OK.
Thanks [
Northern924
you'll need to remove the rear cover panel, under there you'll find the covers, unscrew the one where the raising bar has come out and see what kind of condition the plastic gears are in
robwright
pauljmcnulty
Diver944
ORIGINAL: pauljmcnulty
Cogs are only a few £s from Porsche. A lot more expensive on e-bay. []
and buy two pairs (you'll probably strip the cogs on the first pair while setting it up
