Sunroof
If the roof's never been removed then what were you doing retracting the arms?
I'm a man. And an idiot. [&o]
My thought was to see if the motor, dash switch, cable, gears etc. were working, despite nothing when trying to "tilt" the roof. Trying with it in "accessories" seemed sensible, and does prove all these are working fine. Of course, I should have thought that I might not be able to latch it back in again. [&:]
Hi Paul, Had the same problem with mine. If you open the boot take the panel off the nearside rear wing and clean all the connections on the motor hopefully it will work. Mine did, only took about fifteen minutes.
But - try taking the roof out now that the arms are retracted and then refit and see if the micro switch clicks into action
Not even needed, just banging the switch and I got contact for a couple of seconds, so the roof is secured again. Thanks to everyone who didn't steal my car today....[:D]
So. A thought occured whilst thrashing it around tonight. Why is there a switch in the front, and could it just be by-passed? It senses when the roof is in place, but by definition, I only want to use the electrics when the flippin' thing IS in place. It's not a clever switch that knows you've removed and replaced the roof, and does something different; it seems only to avoid you having the option of raising and lowering the arms when the engine is running, and the roof not in place?
I guess I'm missing something, but can't for the life of me see why it's needed. [8|]
ORIGINAL: pauljmcnulty
That's fine Paul. I probably won't steal it tomorrow either.
As you said - it tells the car whether the roof is in place or not. And (little known fact coming up), it is wired into the central locking system. If you turn the car off, replace the sunroof and then lock the car then the arms move up and engage in the back of the sunroof. If it didn't have the switch then it wouldn't be able to do this, as the car wouldn't know whether the sunroof had been replaced or not.
My front switch packed up, I took it out and sprayed it with contact cleaner while exercising it and it started working again and has been fine since, some years later.
If you get stuck again there is a nut on the motor (pic in the handbook) you can wind manually there is a tool in the tool kit too - might be the plug spanner.
A timely thread.
My sunroof packed up one day a week or two ago. I opened it on the way to work and then it wouldn't close. Just pleased it didn't rain that day. Closed it manually and it was added to the "list"
I had a spare hour tonight so I took the rocker switch out and followed clarks garage. Its a bit vague on the testing of the console switch so I wondered if anyone who has a spare and a multimeter would confirm they can get the same results as CG.
I found the first bit (2-5 and 1-3) is with the rocker switched to the close roof and the others for the open roof - at least that's what gave me 3 out of 4 correct resistance readings. The last one 2-4 gave me a reading of 1 regardless of switch position.
So maybe that's my problem? Anyone out there with chance to corroborate the findings?
I'm a bit reluctant to take the roof out but the centre switch appears to be next to test.
Hi Oli,
So......
Assuming one didn't know the roof has this self-closing thing (I didn't), what purpose does it serve, and would by-passing the switch have any negative effect?
I could understand if the roof closed with the locking. I've lost count of the times I've left it open and the alarm has gone off, or it's rained. My car does tend to get driven to events with the roof open, as I almost always have it up, and I always forget to close it before walking to the other side of somewhere like Silverstone! Automatically re-latching the already closed, and just replaced, roof is nice, but in reality I'd guess that few of us take the panel out that often, and then forget to secure it?
Paul,
It's a while since I have done this sort of thing, but you need to do what's called a 'Stateful Inspection' of the machine and think about what effect removing the switch would have.
The switch tells the car whether the sunroof is in or not. This allows it to:
1. Retract the arms if the roof is in, the arms are at 'Down' (not 'Retracted'), ignition is in Pos1 and the 'Up' sunroof switch is pressed. If the roof is NOT in under these conditions then the arms will be already retracted - i.e. this is a state you should not be able to get into if the sunroof is out of the car (arms in the 'Down' position but the sunroof is out of the car).
2. Extend the arms to engage with the roof if the roof is in but the arms are 'Retracted' and the car is locked. If the roof is NOT in under these circumstances then nothing happens.
3. Extend the arms if the roof is in, the ignition on, the arms 'Retracted' and the 'Up' sunroof switch is pressed. If the roof is NOT in under these circumstances then nothing happens.
There are probably other such states which apply but I can't think of them at the moment.
If you just wired the switch out of circuit then I think the system would get confused and you may find you can get into a state you then find hard to get out of (but I have had too much to drink this evening to work out the details of that!)
What would be easy to do would be to remove the centre roof switch and replace it with a manual toggle switch on the dashboard, which you need to flip whenever you remove or replace the roof.
You may also, with a bit more rewiring, be able to make the roof work without the centre switch if you were prepared to sacrifice the self-raising of the arms when you lock the car having replaced the roof. Again, that would require more thought that my brain is able to give at the moment. (Actually, if push came to shove you could wire the switch such that one side moves the arms one way and the other side moves the arms the other way, and you just have to learn when to let them stop for the various positions; Up, Down and Retracted.)
An auto-close sunroof would be a fairly easy thing to arrange with an aftermarket alarm. In fact, it's one thing that I keep on meaning to wire my alarm up to do whenever I have the time and a warm enough day to work on it. However it's not an urgent job so it's right at the back of the list ...
hi there, should just lift out.... if you search on this forum you will see how to do it.
basically you close the sunroof fully. then undo front clips, then i give a gentle tap to the rear pg the sunroof and it comes off.
You will need to check the handbook or on this forum for the procedure to de-latch the lifting arms think from memory you put the key in the first position i.e. aux position unless an early car then think there is no first position, then with the sunroof closed already operate the sunroof switch as though to close it and the two lifting arms at the rear of the roof should retract into the car, then the roof can be lifted out from the rear by tilting until high enough to remove be careful of the front hinges which go into the front edge of the roof near the interior light there is a microswitch in there that is to confirm when the roof is in or out so the lifting mechanism will or wont operate depending if in or out.
There are lots of postings on this, and when operating the roof you have to be very careful not to strip the gears that work the arms.
Mine ('89 2.7 Lux) had stripped gears when I got it, and I rebuilt it plus sorted out the slipping clutch, so here are some notes:
(Check Clark's Garage procedures here - as ever they are superb on the subject)
1. Mine opens when the ignition switch is in position 2 (ie "normal - on") and you press the switch down - it stops on microswitches.
2. It closes (rocker switch upwards) when the ignition switch is in position 2 but sometimes the arms don't stop at the roof-closed position but carry on to their retracted position (as if for roof removal).
THAT IS THE DANGEROUS MOVEMENT - IF THEY CARRY ON GOING, THE SLIPPING CLUTCH SHOULD PREVENT DAMAGE BUT ONLY IF IT ACTUALLY SLIPS
3. If the roof is in place and the ignition switch is in position 1 (accessories) then pressing the switch upwards moves the arms to the roof-locked position.
Many people, me included, back off the tension on the slipping clutch so that it just works the roof, which is in my case a lot less than the factory setting.
The factory setting on the slipping clutch is quite tight, and is OK when the gears are both working in unison. With wear and stretching of the cables, what is likely to happen is that one arm stops first, the motor strips that gear, followed a moment later by the other one.
The motor, clutch and microswitches are under the side carpet in front of the battery on my '89 model.
My suggestion is to make sure that you never allow the arms to retract fully and hit the end stops; you can take the roof out if they are couple of mm short of the stops.
Operation is all very logical in a strictly Teutonic way, if you have a degree in meta-philosphical analysis that is.
ORIGINAL: Veerzigzag
Very informative - thanks.
