Suspension & Brake refresh
- Thread starter andy watson
andy watson
Moderator
Catamax944
andy watson
Moderator
Catamax944
Yeah but only the konis because they mount with that bottom bolt but all other inserts dont have that. That is a feature koni offers up , it doesn't mean they are rebuildable . I can think of 2 other mods right off the bat to mount them in the late struts but it's not a bolt on job .ORIGINAL: Eldavo The 87 struts are rebuildable, just not as simply; there's a guide on Paragon's website as you need to do this to fit the Koni inserts. It involves drilling a hole in the bottom of the strut to let the oil out and allow you to bolt the new insert in and cutting the strut down a set amount too.
944Scott
Dont know, but the 250 turbos without Konis had smaller diameter springs as per the 968, the koni equipped cars had conical springs which are narrower at one end. Cant remember if it was to clear the tyres or brakes. I think most 944 s2's also have the smaller dia springs. I think the 220 turbos had the larger dia front springs. So front struts need a spring perch to suit the springs. As has been said to fit inserts to later struts you need the special inserts (koni only as far as I know) and to adapt the old struts with cutting /drilling.ORIGINAL: 944 man I honestly dont know, as a 'bracket spring' sounds a little like a 'flange key' - rather generic and meaningless if youre starting from scratch. Hopefully someone else will be more enlightened. Alasdair is good with this sort of thing, in my experience. If you read his Al, can you think of any reason why damper kits which incorporate front springs are listed as 'all except Turbo/S2'? Simon
andy watson
Moderator
Well the Spax inserts are correct, what I don't understand is that nowhere does it say about drilling, cutting and adapting existing struts all of which I am not happy about undertaking. I have spoken with the supplier and they can supply the RSX full coilover kit for £590, so I think I will go with that. Thanks for all you help guys, without your knowledge I could have really ended up one of those S*#T streetsAs has been said to fit inserts to later struts you need the special inserts (koni only as far as I know) and to adapt the old struts with cutting /drilling.
andy watson
Moderator
Simon, haven't got it in writing but yes that is what I have been quoted over the phone, I will be sending the PSX kit back tomorrow which is subjec to a 15% Spax handling charge and then placing the order for the RSX kit. I have spoken with Spax regarding the handling charge and hoping to get the waived due to the circumstances Ii am returning the kit. The guy I am dealing with at Venon is Simon.ORIGINAL: 944 man Andy, can you confirm that Venom have offered to supply a Spax RSX118 (complete front strut with rear coilover) kit for £590?
andy watson
Moderator
Gavin, Just checked, yes they are! Thanks for that Might help towards getting the 15% knocked down!ORIGINAL: gajh I think dc performance are doing them for £565
944 man
