Suspension & Brake refresh
- Thread starter andy watson
andy watson
Moderator
Oli, there are no notches for the spanner, so sealed units they are! Thanks for all your help saved me a lot more wasted timeORIGINAL: os951 Simon, it does not make any difference if your car is a 1987 or never series two car, a 944, S2 or Turbo. All of these uses sealed type strut. If you want to use Spax insert, your strut needs to be modified as i have done. In my picture strut is from a 968, which use similar strut as S2. 968/S2 style strut uses small diameter spring. 1982-86 strut cannot be use directly on later cars because spindle attachment hole distance is different compared to later one. You can use modified 944 struts directly under 951 and also under S2, but you must use 951 springs, S2 springs won't fit.So do these need cutting off to remove damper or do they unscrew?Little bit difficult to tell from that angle. Check out the cap. If it is similar to the one seen in the picture, you can open it. If not, then cutting is required.There must be notches for spanner.
Suitable spanner![]()
Ex Skyline
andy watson
Moderator
No, ABS have nothing to do with it. It's true that ABS caused changed of ET but there are '87 & '88 models without ABS and sealed type struts. My '88 951 and my son's '87 951 came originally without ABS and both of them had sealed type struts. Last model year which had possibility to renew struts with inserts was 1986.I think all the pre ABS cars had the struts that could be renewed with inserts
andy watson
Moderator
Venom are not confident that they will fit my car and are not happy to supply them, so rang DP and they are not sure if they will fit and are going to get back to me! Venom, said they have had a few issues with different Spax kits not fitting and are going to be taking this up with them.ORIGINAL: 944 man Im confident that the RSX118 kit will fit my Turbo, yes. Im seriously considering buying them, although Id have been happier if the promotion had continued into the new year.
andy watson
Moderator
andy watson
Moderator
Diver944
No - Andy that looks terribly non standard and the colour scheme is just too garish to bear. I shall PM you my address so I can come round and take it all off your hands [ORIGINAL: andy watson Looking good?
