ORIGINAL: andy watson
ORIGINAL: 944Turbo I think if you lower the rear of the car with the wheel on you will be able to get the bolt in, you just need to 'compress' the torsion bar spring. You can then worry about height adjustment on eccentrics later. The Spax kit looks good!
Top man Tony, all sorted that was easy! Thank you Well that is the kit all fitted now, just waiting for the calipers to be returned and then I can get her off the axle stands and adjusted. Had hoped they would have been back by now[
] Went to fit the new HEL brake lines and found they do not fit[
] what is the matter with these suppliers? That is incorrect info and PSX kit sent by Spax (after checking via the phone with them twice!) Brake calipers taking far to long due to wrong kit being sent for the refurb HEL brake lines wrong size (after double checking via the phone)
