Neil Haughey
Chris Dyer's in car footage up on Youtube http://www.youtube.com/watch?v=jnlOt52K0Rw Brilliant listening to it, that is one guy who sure enjoys his racing, almost like that clip of Senna winning in Brazil.
Better make sure the skates are sharp then ,, hey....Ever little bit helps...[][][]ORIGINAL: paulf968 ........ don't worry about diesel from the trucks Paul, there is always plenty of aviation fuel liberally sprinkled around the track !!!! Any sign of moisture and we will be skating whatever happens..............
Maybe that's why its not been included in the Championship regs yet?! We have 3.2-engined 987s in our series but to date you couldn't draw any conclusions as to whether they are any better/faster than a 3.2 986. At Snetterton in the wet, a 987 won all three races; at Cadwell Park in the dry a 986 won both races; at Brands it was mixed. #88 Chris.ORIGINAL: Neil Haughey Something else I have noted, not an anomaly but a model many may have overlooked. The post 05 boxster S 987 variant. As a stock road car it had almost identical track test lap times to the 996.2...
From a spectators point of view I completely agree with this. The club champs has never been so much fun to watch as it is now. []ORIGINAL: bazhart There are very few competitive events that try and fairly mix it between lots of different models and succeed but if you look at the models in the results lists you can see that there is a lot of good fair competition amongst the teams and drivers and something for everyone to follow and get excited about.
I guess it would also be quite an expensive car to build though, even though the cost of used Boxsters seems to have taken a serious hammering recently...ORIGINAL: Neil Haughey It is in the PCGB regs, Boxster S 2005-2007 280 Bhp. Its in the two Appendix lists just ahead of the 993. Its weighted up pretty heavy though, only a bit lighter than the 996 but of course in many ways this makes the prep vastly more straightforward. I think maybe everyone just overlooked that model, its an oddity in that its such a new car relative to the majority of those included.
I will have a dig around but this was on US sites such as rennlist or planet9. I imagine they read them out of the workshop manuals and converted from N/mm to lb/inch so yes as the springs are conical very hard to get comparable figures from. A few places have spring testers though, I can recall many years back seeing one at AVO in Wellingborough. Its a side point as I don't know if anyone does it in the club championship but I have read and heard on ten tenths about testing all spring sets used on a race car if for nothing else but to verify that the stated rate is reasonably close to spec and not have one spring at the top of the variability and the other side at the bottom.ORIGINAL: bazhart That's interesting Neil I would like to know the figures for the various spring rates please as the std ones are conical and therefore of variable spring rates - difficult to compare with linear springs, Baz
Assuming the wheelbase wasn't made longer wider track should in theory always make a car more nimble all other things being equal as the ratio of wheelbase to track width has been made smaller. I suspect something else is going on perhaps negative impact of bigger wheels etc. etc. Certainly the tail happy aspect sounds like a possible symptom of a wider track, we space out the track on the S2's 40mm wider than stock and it makes a massive difference to how the car drives, far sharper on turn in but perhaps a little more edgy, difficult to say as so many other changes. Paul F once said on this forum about spacers on the 968 that without them the car just wouldn't be competitive.ORIGINAL: berty987 The 987 has a wider track which improves stability but reduces the turn in , as a result the 987 isn't as "agile" as the 986 IMHO. The 987 also feels a little more "Tail Happy" than a 986 , perhaps due to the wider rear track. Porsche experimented with a softer rear ARB to reduce this effect, but it never made it to the road cars, this may also explain why PSM became standard in the 987.
