Hi Neil, One of those nights with your head buzzing and too much to think about so decided to get up and try and empty my head by offloading some of it. I am too busy this week to send any more torque figures but what I really would like you to do (if you have time) is to run your simulation with the same car and same peak bhp - but different torque curves. i.e. your 996 simulation (weight distribution, 300bhp etc) but change the torque and see what difference it makes to the lap times. Comparing it to a 968 would be good because the 968 is 240bhp so the 996 is exactly 25% more bhp (300-240 = 60, 60/240 = 0.25 = 25 as a %). I don't have the graphs or chart figures here tonight that I E-Mailed you yesterday but if you look at them I think you will be able to calculate the % ncrease in torque over the 968 at whatever steps your simulation programme has in it (say 4K revs, 5K revs etc) Use the same calculations - i.e. at any revs you have information for - (996 torque - 968 torque)/968 torque - and then increase the torque in your simulator by the same %. What this should show is that for the same weight car and the same power - the difference round a circuit that extra torque would have. I presume that when you drive on the simulator you do not just go full throttle as soon as the apex of the corner is passed but have to gradually feed in the power as you exit (to avoid losing rear wheel traction). If so it would be important to get on the throttle as soon as possible and in the same gear you would use on the track. You can see from the videos drivers post that it is usually roundabout 4k Revs that they start to throttle up. This makes a big difference because once on the straight the gear change revs reflect the drop in revs from peak revs to whatever the gearing makes the revs drop to in the nest gear. Although the bigger engines have more torque low down - this is not really used on the straight and there is relatively little difference in the torque as a proportion of the maximum bhp (which we are trying to control with weight) as the engines rev drops are small then and 4K is never used. the big difference is that initial acceleration out of the corners that starts the bigger engine'd cars off down the straight a few mph faster - which is a difference they more or less maintain until the breaking point. I don't have time to replicate that this week as I am busy on 2 projects that have date limits this week but it would help to equate the positive difference in seconds it makes from which the change in time that you think the weight makes round the corner and provide a result that explains the shorter time they take from apex to braking for the next corner. This is also why my methods of simulation confirm (for example) how we managed to win at Brands Hatch (all be it that Pete's car was out of it). Brands has three main corners with adverse camber where you cannot used the potential benefit of that extra torque on exit because paddock drops away and limits throttle throughout the drop, the corner after druids also drops away (and it is too easy to run wide if you throttle up too much) and clearways starts off negative camber (just when you would be using that 4K revs area) but then unwinds as you can get onto full throttle. Plus being such a short circuit - the straights are too short for that initial speed advantage to build up before braking. Silverstone (at the other end of the scale) has lots of places to use heavy exit throttle and longer straights. All this will help create a fairer way to weigh the cars. The differences in circuits will always mean some cars will be faster at some circuits and some at others - but what we want to avoid is one model being faster at every circuit (all other things being equal). I am trying to create a system that will result in more cars and different models being closer together throughout the race and different winners at different circuits. IMHO nothing could be better for the series than seeing 10 or 12 cars in close formation, changing places and battling for the results. Formula 1 would give so much of they could create just that. Quite apart from that - all of us here at Hartech agree that it would be much more of a challenge, much more stretching and much more satisfying to be trying to make our cars get to the front of such a close race than simply to run away in the lead with the chasing pack unable to close due to an unfair advantage. We didn't go in for this just for the glory of a Championship or a podium and the closer the car's performances - the greater we will have to think, test, try things and work hard - which is what we are trying to achieve. By comparison - finding you cannot beat a particular model - just because it has such an unfair advantage - simply de-motivates everyone from even trying (as it can be a waste of time and effort if the advantage others have is insurmountable). I think the same applies wherever your car, driver or team effort places you in the race - the challenge is to recognise that if you can improve something - even a little - you can move up the rankings - that for me is what it is all about. No one will bother if the gap is too large. I agree with you that the problem created by the additional torque of bigger engines does make you think there should perhaps be a capacity limit for different classes - say class 1 - 3.2 and upwards and class 2 - 3.2 and downwards. But then you have the 3.2 Carreras and the 928's to consider. Perhaps 3.2 and upwards and less than 20 years old for class 1 and over 20 years old for class 2 would do it? These issues will become more important as models like the Cayman, larger engine'd Boxsters, 3.6 996's and 3.6 and 3.8 997's gradually are allowed in - as all will have more powerful, bigger and more torquey engines. Fortunately the capacity, improved handling, 6 speeds, torque and age - seems somewhat to link together. In 5 years time it may be necessary to add another class as the older cars will then be the 996's etc so perhaps an age limit for different classes would be better? Hope you can manage to test those differences and thanks for the efforts. Baz
