tyres
- Thread starter Guest
Kevin Welch
Diver944
Best bit is they were only £75 each fully fitted, and this was for 245/45 ZR 16 that the Turbo has on the rear. The narrower S2 tyres should be a little cheaper
Tony
TTM
ORIGINAL: Fen
You'll be lucky to find S 02 next time.
Not so sure, they are still well available down here in France.
sawood12
Lemon
Great in the dry, seem to be reasonable wear rate, although I have only done 4,500 to 5,000 on them with no real major wear and OK in the wet.
I am sure if you spend more you get what you pay for but they seem to me a great tyre.
cheers
Lee
Kevin Welch
I'm running Toyo Proxes T1S on my Rover[
lali
They are a superb tyre and when you consider how little they cost it makes them an INCREDIBLE tyre. I have and do use them and their predecessor the FK451 on as many of the cars I have owned as possible:
M3,M5, 330D, 120D, E200 Estate, 968's and 944S2.
They also make a reasonable wet Trackday tyre...
geoffbateman
geoffbateman
ORIGINAL: Hilux
Falkens - seconded, great tyre, good on track (wet or dry) too.
So impressed for the price that I`ve put them on my old Landcruiser (obviously a different tyre but still with good grip and wear compared to BFG which cost some 30% more)
Thanks a lot, I'm going to check out my local dealer this morning.
mik_ok
But.... you're unlikely to solve your problem. A 10" wide rim is 254mm wide, and you have a 265mm wide tyre. On a new rim, the tyre width is unlikely to change significantly.
Wouldn't you be better with a slightly less heavily offset wheel?
