blade7
Well-known member
PhilKent said:Set up the throttle position calibration, start the car, drive! A couple of hours driving max with a laptop running to map the fuelling (which is automatic) should have calibrated the fuel mapping and your done, 'burn' the config to the ECU. Fine tuning on a rolling road is optional.
Hi
When you say 'burn' is something like Ostrich required or is the updated map just downloaded from the laptop. And do you know how many maps can be stored ?
