what did you do to your 944 today
- Thread starter colin944
WBray
ORIGINAL: mike220 Does it wofk properly if you 'flash' main beam rather than putting it on permanently ? I had the same issue and it was within the stork assembly. If you get the same results when 'flashing' (ooh err mrs) then it'll be the bulb mikeORIGINAL: WBray Noticed something odd the other night and rather than start a new thread thought I would ask here as hopefully its quite simple. When I have my lights on they are all working fine. When I put full beam on the passenger side pop up light turns off and will turn back on when I take full beam off. Does anyone have any ideas? Cheers,
Hairyarse
Wow, either Santa has been this year or you dreamed it! [ORIGINAL: _ian I moved the 944 to it's new London home. At long last I've managed to find the elusive Central London parking space. Better yet, it's secure and cheap! A rare combination...
MJL944
ORIGINAL: MJL944 Got rid of a squeak coming from two panels of leather rubbing against each other in the back rest of my driver's seat. Sticking my hand under the leather panel and rearranging the foam in the back rest and the way the edges of the leather panels sat in relation to each other did the trick. Also did a temporary (aka 'bodge') fix on my droopy sun visors which both flop down at least an inch or so. I pulled the sun visors off to reveal the small rod that the visors pivot on and this rod is what is failing in its duty to keep the visors wedged up flush against the roof:First up, I tried this bodge using small elastic bands but it didn't work!
Then I tried wrapping just 2 layers of very thin surgical tape around the pivot bar like so:![]()
Et voila! The visors now stay nicely up against the roof. However, this is only a temporary fix as once you move the sun visors down all the way a small metal piece in the locating hole within the visor scores the tape thus removing, from where it is needed, the extra diameter of the rod and the friction this creates. I've owned my S2 for over a year but I've never actually needed to use the sun visors for their intended purpose so this 'fix' should last me a while and it doesn't even take 5 minutes to remove the thin tape and replace it when it becomes scored. Maybe someone could experiment to see if a stronger tape will withstand the scoring better thus providing a more permanent fix? From what I can see though, operating the visor will score any tape used and tougher tape, if it bunches up after being scored, may make it very difficult to remove the visor from the pivot bar without damaging the visor. I'm not sure if new visors are still available but American suppliers seem to quote them new at a ridiculous $80 or so - each - so wrecking your current pair would be an expensive mistake. I suspect all used visors available from the usual places will be quite floppy already as the design of the pivot bar seems to be pretty poor.![]()
MJL944
Diver944
The clip at the other end of the visor is only a few pounds and provides a lot of the friction required to keep the visor against the roof. It's worthwhile replacing them first.ORIGINAL: MJL944 Thanks Gents - good to know the visors are still available and actually, yes, £39 seems pretty reasonable
MJL944
My experience is the same as Andy's I'm afraid. I replaced both sun visor clips (nice and cheap from local OPC) last year and this made no improvement to the droop on either visor. At the time, I even tried putting some tape around the small bar on the visor that clips into the clip to increase the friction but, alas, still no improvement. It seems that once whatever it is in the innards of the hole in the visor that the pivot bar disappears into breaks down you will get that irritating droop, until you improve the snugness of the fit of the pivot bar in the sun visor hole.ORIGINAL: Diver944 The clip at the other end of the visor is only a few pounds and provides a lot of the friction required to keep the visor against the roof. It's worthwhile replacing them first.
MJL944
Good Man [ORIGINAL: Andy 944 Plugged in my IPod, put the Sunroof in the boot and went out for a long thrash through Kent & East Sussex, bag of chips in Rye![]()
