George Elliott
sounds good - unusualnot like a regular dealer these guys are enthusiasts that's why I use them!
ORIGINAL: Eldavo Went to change the damper adaptor that connects to my AN fuel line and saw that the damper was loose. The bracket had cracked previously and been bodge welded up, a hard day on track and it had started to come apart again. Luckily it was just the bracket edge and it hadn't damaged the rail itself. Sanded down a spare rail I had, a coat of primer, gloss black and then 3 coats of petrol resistant lacquer. Decided I wasn't going to replace the plastic rail cover so wrapped the injector harness in red self-amalgamating silicon tape.
How much are the tap in rivets? Just so you no if you ever need to replace the drive cable for the sunroof they are NLA from the OPC.ORIGINAL: VITESSE Replaced both sunroof gears last week using Clarkes garage info-lubricated everything with aerosol gear grease-had to adjust microswitch bracket position afterwards to get tight sunroof closure but now runs quite smoothly. Most time seemed to be spent using a mirror to check adjustment of cam/microswitch positions-almost need an ear trumpet to hear the switch clicks with background noise from passing traffic-perhaps I'm going slightly deaf! All parts supplied efficiently with member discount by Chester OPC-Steve Physick now back in spares & very pleasant to deal with-I also ordered some spare black screw caps,2 seat belt trims for the side panels,a set of the plastic tap in rivets to repair a spare sunroof(which will be for sale).
Was that the TopGaiters ones from eBay? I took delivery of a centre console cover this morning, I'd seen the A-pillar trims they did but couldn't work out how the screws went in??? As for a leather armrest, I thought about it but I got a bit carried away . . .ORIGINAL: 944Scott Today I covered my A pillars with some linen coloured leather because some numpty when they replaced the screen damaged the originals. Also covered the cubby box lid with some matching leather.
No, I have a little man under there who taps on the firewall if there's a problem.ORIGINAL: VITESSE Dave-do you have a system of mirrors so that you can read the gauge whilst on the move?[]
Frenchy if marine blue is dark blue then I have a pair.ORIGINAL: Frenchy Dave re route the braided pipe for your gauge it will rub and wear the alloy boost pipe eventually...................you know i am right ! Regards windscreen change always remove A Pillar trims as they always get snigged by the windscreen fitters cheese wire, warned a friend about it and guess what he can now not get hold of marine blue A Pillar trims, OPC do not even do them.
