what did you do to your 944 today
Steviebear said:
Going to get my original 15 inch Tele dials refurbished tomorrow but struggling to find 215 60 15 tyres to fit should I go up to 220 or reduce the depth any ideas. I used to run Goodyears but cannot find any in stock anywhere. What are you others using out there, sorry cannot run to Pirelli`s
I get my tyres these days from 'Blackcircles', not many on their list for your size but a few to choose from which aren't too bad in price, not sure how they priced two of their options though...crazy money for Avon and Pirelli.... [link=https://www.blackcircles.com/order/tyres/search?width=215&profile=60&rim=15]https://www.blackcircles.com/order/tyres/search?width=215&profile=60&rim=15[/link]
Pete
Just a comment on your fan switch Pete , I have noticed that as the fans are now older and full of bearing dust, that the load to start them spinning is getting larger, this tends to spark the rad switch contacts harder
i have had one or two now with the contacts welded together
it it is not practical to take the fan motors apart, although it is possible
the americans that suffer with with more dust than us wash them out with contact cleaner then fill them with silicone oil and then they spin more freely and have less load, no more blown rad switches
It's a good point, I have sprayed as close as I can to the bearing areas...I have been toying with the idea of stripping the fans down and see if the bearings can be replaced. I haven't looked into this yet as I have so many other things that need doing, bearings are relatively cheap to buy assuming that Porsche aren't using some odd size and that they haven't made the housing impossible to strip down.....this is just another one of those jobs on that very long list of what I'd like to do as a preventative action. The fans do make more noise than they should so i'll need to do something about it sooner or later.
Pete
I have taken a dead one apart and it's far from easy the case is crimped together so requires a little force to open
The front bearing behind the fan is a sealed deep groove single row bearing, the rear bearing is the presoaked selflube phospher bronze type
The real fun is getting the commutator back between the brushes and the case back all in one go
Thanks for the heads up Martin..interesting to note that the rear is PB, I have plenty of PB102 stock so could turn up bearings from that, did you by chance make a note of the front bearing size? I bet they don't cost more than a few quid. As for getting things back together...not my problem, I'll let my son do that, he has a natural knack for such awkward things. He rebuilt either my A/C compressor or Alternator (I've forgotten which) easily enough...Ijust wish he wasn't so damn busy. He's just rebuilt the engine from a lovely Golf TSI, fitted new clutch, brakes, stripped everything and given the car a complete respray all in a few weeks, I have to say it looks mint, up for sell once he's bedded the engine a little. If only he could spend a few weeks on mine, he did say some time ago that he'll respray my car for me one day...I suspect I'll have fallen off my perch by then....:)
He has driven it....many years ago now, I think he was just 18..I was busy working at the studio's..IIRC doing 7 day weeks on Harry Potter 1...I desperately needed two new rear tyres, he collected the car from the studio's and got them sorted for me....:)
So the end of a very long saga. Ever since I got the car, 10 years ago, there has been something amiss with the alternator drive belt action. Had noticed when going through a large puddle the belt would squeal and pretty much the alternator would not be turning as the voltmeter dropped down to 12v. Then shortly after if would screech a bit as it re-gripped and began charging again. I would also get this phenomenon on start up if it had been raining heavily. Start up car, alternator not charging, few seconds later a little squealing accompanies the charging coming to life, voltmeter climbs to 14 and all is good. Loose or goosed belt you would assume. Wrong. A little while later I start getting what sounds like a bearing whine. Suspect alternator. Change alternator and belt, goes away for a bit. Comes back. Suspect alternator again, what else can it blooming be? Repeat process, repeat outcome. Car's had about 5 alternators now! Move on to next suspect, replace AC compressor, needed one with an intact nose seal anyway so changed it, changed belt, all good for a bit. Symptoms return. Much head scratching. Take it apart again and notice alternator drive belt has slithers of metal inside the grooves. I know I've changed alternators and AC compressors so only remaining suspect is the crank pulley itself. Boom. Only took about 8 years to figure this out! Enquire about cost of new crank pulley from OPC, £102 inc discount. Ouch, so whilst I swither about this I throw on a new belt, with no metal inside, and over tighten the belt to help the disintegrating crank pulley grip better, kinda forgot about it as was mostly performing ok with belt tight. Then we get an unexpected gas evacuation from AC system. Not put 2 and 2 together at this point, AC system was reconditioned and many parts replaced, but not all parts. Its 29 years old so highly likely something I've not replaced has sprung a leak. Forget it and move on. Then I start to hear a bit of what sounds like bearing rumbling on start up and idle. Defo coming from alternator belt area, clears when revved and heated up. Now put 2 and 2 together and assume tight belt has damaged AC compressor bearing, in turn damaged nose seal, and explains gas loss. Time to order that crank pulley! Decide to acquire a re-con alternator at same time, as had likely damaged that bearing also and had no desire to complete the job and realise I needed to do it again! All bases now covered. Fitted the crank pulley, tighten to a million torques, fit re-con alternator and AC compressor and finish job with 2 new belts. Tighten to recommended level, good idea that (!), all noises gone! Phew. Also did an oil change and changed the o-ring on the low end of the trans oil cooler loop which had a small sweat. Topped up gearbox oil then popped off to my mates house to get the AC system pressure tested (ok), vacced and re-filled with gas. All good now but would have been considerably less expensive had I changed the crank pulley sooner! Anyway I have icy cold air again in time for this heat wave people are talking about............... Stuart
Today I was going to re-glue the rear seat back in place, that is until i saw the big puddle of water in the seat well had returned. Well to be fair I haven't fitted a new sunroof seal yet but thought as the good weather is returning and I hadn't seen any signs of the water returning since fitting the new inner sunroof seal a few weeks ago and it has been raining since, it was probably ok to put things back together. However last night we had a lot of rain which clearly overwhelmed the old outer seal. The drains are clear so you would expect the water to drain but I guess with a worn seal capillary physics is ruling the day. Of more concern was water back in the support brace that runs across the car in front of the rear seats. Before hand I thought that the water had got into the cross member by overfilling the seat bucket and running into the two large holes at the front lip of the seat. This time I wasn't convinced as the water in the seat was only about an inch deep, it would need to be approx 4 inches deep to reach the holes and get into the cross member. Although the roof drains seemed clear I thought I'd do a test by pouring water down the drain holes, well actually SWMBO poured the water while I observed it's exit. Surprisingly the drain above where the water has been getting in (passenger side) worked perfectly with the water exiting out past the rear wheel slightly inboard. I pulled away the boot side carpet and could see that no water had escaped from this particular hose, I had thought that it was from the hose somewhere that water had been running down the inside of the car finding it's way to the cross member...clearly this was not the case. I then repeated the exercise for the other rear drain hole on the drivers side. This time the water wasn't all going through the rear drain hole, I removed the side carpet to discover that the hose was broken, well not actually broken, it had had a 'makeshift' connection made with an old piece of black hose into some metal pipe which had corroded and thus wasn't fully connected, worse still is that the 'Y' connector which should connect to a hose in the fuel filler recess had no hose attached resulting in lot's of water running down the inside in front of the rear wheel and I'm surmising then finding it's way into the cross member. On discovering this something became very obvious, I now knew why my drivers inner sill below this point had corroded during the cars lay up. Water had been draining from both the roof and fuel recess drains into the car running down to where the rust had attacked the metal. This was fixed 3 years ago for it's first MOT, well just after actually but the MOT station knows my son and knew the car was going directly to his garage 1/2 mile away and so he passed the car even though it had a hole in it's inner seal, as I said this was all dealt with immediately. So today I have fitted a temporary hose section , the effected area had been covered in POR15 which stops all rust but in the near future we will get the car up on the ramp again and give this area a good checking over. I'm sure that it will be fine but better safe than sorry....
The moral to the story...check your drain hoses chaps...:)
Pete
Finished doing the belts and rollers, started her up, got her up to temp then drained the oil for an oil&filter change. Going to replace the oil cooler feed pipe as well as it's developed a slight weep. Will seek out OPC price or have one made by pirtek... Also drained the gearbox/diff oil and need to fix a weep here too. Took off the oil cooler and noted some vibration chaffing on the lower connector by the oil pump. Will need to either shim it or replace/repair the connector and housing...the job's keep coming...anyone got any experience of this?
Also ordered some bilstein B6's :)
Took her for a run and she was perfect, I did notice the temp was up when she was ticking over outside the garage standing, soon went down to normal once on the road, sat ticking over while I opened the garage I have down at my mothers, temp way up and when i pulled her in the garage she dumped a load of coolant, looks like the fans never kicked in (thermo switch) back down tomorrow to top the coolant up and hopefully no damage.
Bodyshop on Wednesday for some loving, then nice new crossdrilled discs along with refurbished shiny calipers pads sensors etc.
Hope I am not taking the head off, it is fitted with a Cometic head gasket which are pretty bombproof.
Replaced the offside front balljoint on the red car at the weekend with help of my son Nicholas-fortunately it was already a replacement so didn't need to drill out rivets-clamp bolt was a bit of a b****r to remove-once out it appears to have not been put in correctly but without a new one at hand,I ran a die down the threads to remove burrs .
Frenchy:- I've stopped filling my header tank to the Max mark-now leave it halfway & any water loss has stopped.Well after fast runs down & back from Donnington the weekend before,no loss at all despite the heat.When I say fast -I only mean about 80mph or so down the M6 & A50.
Did you go to the Historic? I went on the Sunday - some cracking racing with the Cortinas & minis, and the E-types
Yes Ed-but we went on the Saturday -got there quite early as we allowed for Bank Holiday traffic & there wasn't any really.we too really enjoyed the Lotus Cortina,Mini,E-Type races what with the odd brave Alfa mixing it.
Never had an Alfa ,but reminded Nick that he used to be ferried at high speed in the Cortina Aeroflow I had & the well tuned 850 Mini at weekends-but that was in 1967/8 & 1969/74.You could still hammer up the M6 from Stourbridge to Manchester then in the Mini at 95 Mph-used to do 50mpg too.
The DHF was a great day with super setup from R8.[:)]
