what did you do to your 944 today
- Thread starter colin944
Dan944t
am fitting a oil catch can which I’m modifying at the moment before I finally start her up again and then need to replace the feed power steering hose
Diver944
PSH said:suns out, time for a quick polish...![]()
Can you post the afterwards picture too Peter
This weekend I managed to get quite a bit done (I've been working the car since November 2018), a culmination of all the preparation and previous jobs I've completed
[ul][*]Replaced Power Steering Return Line[*]Fitted new Water Pump[*]Installed the Turbo (after replacing the air oil separator seals)[*]Installed the Alternator (after replacing the voltage regulator)[*]Fitted new NGK BPR6ES spark plugs[*]Fitted new Oil Filter[*]Replaced the Oil Pump Drive Sleeve[*]Replaced the Crankshaft Front Seal[/ul]Hopefully not be long now before I can fire her up and listen to the engine again!
Dan944t
the they made it and posted it to my door for £385 all in.
took around 8 days and the owner is called Darren and is really polite and helpful.
I tried to to upload photos but my imgur app has gone up the blink and I gave up trying! Will try redownloading another, beutifall workmanship.
Atb
Daniel
here you go I just went back on it and it’s now working
[link=https://imgur.com/a/GAImlcL]https://imgur.com/a/GAImlcL[/link]
vitesse
Was able to select what I considered the best out of 7 of them but a little subjective methodology-could only base decision on absence of free play.
So today fitted it -bit fiddly single handed apart from my wife holding the steering wheel at appropriate moments & angles.
Dan944t
vitesse said:As my wife's Stone Grey 924S is due an MOT & last year ,my friendly garage told me that they wouldn't pass it again unless the steering shaft was replaced,I tried to order a new shaft -initially from ECP where I got one last year for my Guards red trackcar for £91 inc VAT only to be told that they had non in stock ,they were on back order with Germany ,same at Frazerpart & Design 911 so ended up getting a very good used one from James at Only 9 at Anderton (he's moved into new better premises from Weaverham)
Nice one
blade7
Well-known member
Didn't JMG used to have these rebuilt, and offer them on exchange?vitesse said:As my wife's Stone Grey 924S is due an MOT & last year ,my friendly garage told me that they wouldn't pass it again unless the steering shaft was replaced,I tried to order a new shaft -initially from ECP where I got one last year for my Guards red trackcar for £91 inc VAT only to be told that they had non in stock ,they were on back order with Germany ,same at Frazerpart & Design 911
vitesse
I posted for 2 reasons - as a post for anyone interested
-to advise the lack of availability & that Only 9 have some good s/h ones.
Of course I now have 2 removed shafts 1 from each car ,which could be .reconditioned.If I knew how to get the cup bearings out ( each bore is crimped 4 times to hold the cup in) ,then I would have a go but I imagine I'd need a high speed pneumatic die grinder , suitable burrs/grinding stones to remove the crimps & of course then confidence to know that the new bearings could be safely retained with what metal was left- probably need a bench mill to be accurate enough-plus getting appropriate bearings-all seems to add up to too much cost.
Should add that the steering shaft I selected from the choice of 3 was identifiable as being already a replacement as it had the remnants of the self adhesive label ,new replacements have
vitesse
I paid £50 for the s/h shaft which could last say 17/18 yrs ( existing one removed was the original after 34 yrs /112K miles so although I like to do as much as I can myself,it doesn't make economic sense.
vitesse
If your figure of £80 includes top & bottom bearings,then that's a reasonable price plus postage of course both ways-as above last ECP price was £ 90 or so inc VAT-prices I saw last week for other suppliers varied around £134-£128 inc VAT.
However both the ones I've replaced would really only need the bottom bearings replacing
Nick Andrews
