Pete, When I helped a friend re-build his 928 he found instructions on the internet about how to make a gauge. Essentially, the timing belt on the 928 engine has a long horizontal run, and the gauge was simply a strip of acrylic plastic with a notch cut out of one end it, that fitted over the belt in the middle of this run. This obviously dangled down and exerted a twist on the belt, with the amount that it dangled being proportional to the belt tension. He knew it had to dangle by 15cm, and tightened the belt until it did so. I am wondering whether something similar could be developed for a 944. Oli.
what did you do to your 944 today
- Thread starter colin944
simdel1
Very interesting stuff. The problem is that, being an engineer, I want to understand exactly what is going on. To me the logical process is to get the proper gauge, set it to that, then play with other methods in a scientific way. I'll be looking at min/max limits in a range of condidtions and correlating the alternative methods to the Porsche gauge. Besides, ever since I heard about the sonic tension measurement method I've wanted to try it out. [
]It seems far more accurate than any other method. Yes, I'm odd. [
The 90 degree twist is not the most scientific method at all. I would not want my engine to be done that way. How does the guy measure the balance belt? You can't do that by any other method than with the correct tools. The tools are about £200 to do the job properly. Available from Arn Worx in the USA. [link]http://www.arnnworx.com/catalog/index.php?main_page=product_info&cPath=65&products_id=188&zenid=735ac714d9fb7d066b195c67e526ce09[/link] it means your belts are spot on every time, there is also a factor for tensioning used belts as well so every occasion is catered for. It could cost you £300 to get a so called specialist to do them, save them money and do them yourself! Alasdair
Jonny944CS
Well said Alastair. I experimented with various methods (out of interest like smidel1) when I had my engine on the bench. My conclusion was that the 90° twist method is a 'finger in the air' job at best on a 944.
Good clear access to the cambelt-run is not possible and the balance belt tension is so arbitry that unless you have years of experience - a tensioning tool is the only practical option for doing a proper job and achieving the factory tolerance. One reason that the tolerance window is so narrow is that the expansion of the all-aluminium engine with its fixed tensioner causes the belt tension to double between a cold start and normal running temperature. Therefore getting it right will not only extend the life of your belts, but likely the water pump and idlers too.
This weekend I have visited my OPC to pick up some new seals - and ordered another one when I was there because I bought the wrong one originally. Took her for a spirited run around the local A roads and enjoyed the sunshine, then brought her home for a wash, clay and wax - I think she looks good but since I just finished and can barely see outside it'll have to wait until the morning!
simdel1
Gutted. At least it sounds like it was a relatively low speed shunt. I'll keep my fingers crossed for you. I'm always amazed that they allow cars to drive on that circuit - it's sooo narrow.ORIGINAL: MarkK I bumped my S3 at croft,hope it's not TOO much damage[&o]
My painter friend wants to kill me.Aparently the car has been painted at least 4 times during its life and a couple of times it's not even been rubbed down between paint jobs.The other problem is that the swage line on the drivers door is not straight( i cant see it) and its driving him mad trying to remove previous damage that's been covered up with catalloy.WEnt I last saw it it was all one colour of primer but now hes rubbed most of that off trying to get the panels straight. oops
Diver944
Well it wasn't today, it was two weeks ago but I'be just had to replace the front wing (again) after a 10 ton skip lorry caught it whilst reversing round a corner whilst I was parked up at work. The noise was horrific and it dented the wing, scuffed the bumper and both front wheels (the offside was parked next to the kerb and the lorry dragged it sideways enough to kiss it). The skip company paid up in full and a new Porsche wing is now fitted and painted along with the bumper and both front wheels so I'm all smiley faced again [
]. The dented wing was actually brand new from Porsche last February when I had the car resprayed - doh! Must be one of the shortest lifespan wings ever fitted to a 944
I would have too...... Bet the "old" one has a good bottom....
944 man
I wasted five hours this afternoon cutting, polishing and waxing my pink Turbo. In the end it all came up as red and shiny as the repainted and laquered wing, but I suspect that a little application would make the wing more red and more shiny than everything else. I intend to put that much Meguiars wax on it over the next few days, that itll never need polishing again - even bird squeeze will run off!
