Right making the final changes to the circuit diagrams now. This will be an upgrade for my Lux primarily but also a test bed for lots of nice features for my Turbo. Almost definately final feature list:
*Plug and play replacement for digital board in ML3.1 dme.
*Fits perfectly inside the original DME
*No modifications to wiring loom
*Factory quality installation.
*Exactly the same dimensions as the original board
*Modern high speed microprocessor
*Supports all original sensors inc crank and cam VR sensors
*Supports on board/external MAP sensor
*Supports PWM/Voltage output type MAF sensors without requiring external 12V power
*Supports replacement of switch based throttle sensor with true potentiometer throttle sensor
*Supports additional external analogue input e.g WB02
*Supports all the standard outputs
*Supports wasted spark output
*Support water injection output
*Support 2 relay outputs
*Can take the road speed input from the gearbox
*Can measure knock test signal output from KLR to detect individual knock events.
*Supports two external switches e.g. boost/fuel settings
*On board electronic boost control solenoid
*Supports the measurement of a K-type thermocouple for EGT monitoring
*Modular comms interface that can support bluetooth/USB/radio/OBD2 interfaces
*Provision for traction control module to take opto isolated signals from ABS system.
The software can then be written to take advantage of all these features. I will be writing a laptop based control/datalogging interface for tuning etc. Also will use bluetooth to support mobile phone apps for datalogging and some basic control such as fuel map selection etc.
Thats probably it
