944 Turbo S Engine Rebuild Thread
- Thread starter Eldavo
Eldavo said:Yeah the SFR stuff ”looks” nice but fitment is supposedly hit and miss and actually getting hold of the stuff takes an age and is a bit of a roll of the dice.
Going to have a chat to my exhaust man about potential costs of knocking up a set of new manifolds and a crossover - watch this space.
You could probably put the exhaust stud kit together yourself for less but I couldn’t be bothered measuring and sourcing bits separately, for less than £50 delivered it was an easy decision.
Replacement ring pack turned up today but rather than a picture of a box here’s one of my birthday present steering wheel that I finally got around to fitting today:
Yes I started looking plenty of sellers on ebay selling stainless and titanium studs in various sizes, do they have to have the blank between the two threaded sections or can you use a continuous threaded section?
That steering wheel does look very sexy indeed - how is the feel of it?
I ordered one from ebay (not quite as nice maybe!), but Hermes nicked it. Hoping to get a refund before I try again.
I used an ebay seller for titanium studs and bolts for the exhaust dump valve. Bit ott really, but boy it's light compared to stainless! You can probably get away without the shoulder section and have a full thread, but with what's available, its not really an issue and I can't recall if it's opposite threads or not...probably not...
I wanted some bolts that were pre drilled for lock wire for my wastegate (after a low and ultimately futile attempt at making my own) and could only find Titanium ones online. I now have 8 very light and sexy Ti bolts ready to be lockwired in. Think they were £35-40 though [
Steering wheel feels great, I’ve always liked the CS wheel anyway although some find it too thick. When it’s brand new soft supple leather then even more so. Was about £575 from OPC with discount so cost comparable with buying a used one and having it recovered. I wanted the red stitching so it was a no-brainer to go for a new one.
924Srr27l
Eldavo said:I’ve always liked the CS wheel Was about £575 from OPC with discount so cost comparable with buying a used one and having it recovered.
Genuine Clubsport steering wheel. Porsche 911 944 968 964 928 S SC Turbo etc 5B | eBay
R
924Srr27l said:Eldavo said:I’ve always liked the CS wheel Was about £575 from OPC with discount so cost comparable with buying a used one and having it recovered.
R
Thanks Roger, that’s a fundamentally different wheel to what I wanted though as I wanted red stitching, but I think we both knew that and you just can’t help yourself.
The new wheel also came with a new boss, connecting ring, etc. that a refurbed one doesn’t.
David's right for the exhaust manifold I replaced all the studs with stainless bolts. Makes taking the manifold off and on a bit easier, but can be a pain to line up the bolt holes sometimes. I mentioned 'exhaust dump valve' in my last post. Hopefully you understood I meant Wastegate...
PSH
Pete
I'm glad you decided to stick around regardless and I hope you chose to stay longer (both on the forum and as a 944 owner [
When I said 'shoulder' these particular bolts (or studs, that I've replaced with bolts to be exact) don't strictly have a shoulder, just a plain un-threaded section, not critical for location purposes.
Surely, we all know that if you're a really good engineer, you hardly ever use a torque wrench anyway, we all have calibrated elbows
924Srr27l
PhilKent said:Pete,
Ahh that's known as the Shanked section if it's un-threaded, I've got shoulder Bolts and double spring washers on my front brake hubs (See pic)
R
PSH
BtW..I had to sign the forum conditions again for this second post, if it happens again, the next time I won't make the post
Load of progress today with the rest of the build coming together nicely. Helped in no small part by the fact that when Dean dismantled the engine he diligently put each part with all the relevant hardware and accessories laid out over 3 racks in assembly order.
From the pic I was sent I gather it was a late and cold one in the garage when he’d finished
Head is just laid in position, Vulcan Cut Ring Head Gasket will be another month or so from America. Engine can go back in the car next week and we can fit the head and finish up when that arrives.
