PSH
Looking pretty David...now if you were to machine a small 'V' groove between 1 and 2 piston rings you'd be able to increase boost with no blowby....the other trick is to machine small semi-circle along the bottom edge of ring 1. This encourages pressure behind the ring and again hold higher boost levels. The amount of holes required depends on bore size....I machined these holes in my son's Cossie engine, that required 5 holes. He runs at over 35 PSI. I didn't do the same in my engine as it already has the 'V' groove, probably as it's a 'full-race' piston.
Pete
BTW, my ring gaps are given in my engine build thread..these were caculated using a formula used in racing and then confirmed as correct by IASA's tech department for the intended power/heat output.
Pete
