944 Turbo S Engine Rebuild Thread
- Thread starter Eldavo
blade7 said:How did you get on with Wossner over the dodgy piston coating?
I didn’t pay for the uncoated pistons. The end to that particular chapter hasn’t been written yet.
Had a bit of a weep on part of the steering rack, given the age of it and it was black and covered in 32 years of crud that was probably to be expected.
It took a holiday to Bristol (lucky sod, further than I’ve been this year - well apart from Chernobyl back in Feb[8D]) and spent some time with Western Power Steering. £295 later and they appear to have just binned it and bought me a new one! Pic’s not the best as the bag was full of fluid that had drained out after they’d pressure tested it all.
*edit* - don’t know why the forum software has turned the picture upside down? The fact it’s not replaced it with a picture of a duck is a good start, someone must’ve put a bit more coal in the forum steam boiler.
Next winter’s big job will be dropping the rear end and rebuilding all that, after that I’ll be slapping a different Turbo in and see where that takes me.
blade7 said:Financial ruin. I know a £25k RS4 or mapped RS3 would be a better/faster every day car, but I've got years of history with my 944 turbo.
Pretty much [
blade7 said:Considered asking Capricorn for a price to have it Nikasil plated?
Nah, I think the chocolate would melt. Plus their waiting times are rather substantial, block is sleeved now anyway.
924Srr27l
blade7 said:Hope the sleeves and pistons work well. Now Alusil compatible pistons seem to be NLA, I'd probably have to sleeve my 2.7 block if I ever build up a 3.0. Concerns about piston coating, and Yank supply issues stopped me doing it in the past.
I reckon 10 years from now you'll still be quoting about what you'd like to do with your 2.7 block ! [
R
Got hold of some slightly longer 968 oil pump studs that should be fine but can be trimmed in situ if needed once it’s all buttoned up.
Here‘s a picture of a Hot Stud [
blade7
Well-known member
Eldavo said:Oil pumps on the brain as we were discussing the need to have the girdle flush with the block for oil pump face sealing.
Nip up the nuts on the girdle, and gentle tap the girdle with a plastic faced mallet would be my install method. Doing any mods to the sump?
