924Srr27l
Eldavo said:Also stripped down the cam tower as my DIY paint job just wasn‘t cutting it anymore so off to the powder coaters it went:
Is this picture showing the Cam done ? although the paint looks thin which is a good thing for dissipating HEAT, Powder is too thick really and holds in the HEAT too much
If it's gone to an industrial powder coater make sure the bolt holes are cleaned back to bare metal as any thickness here will make the bolts loosen
even with spring washers (This is all something I've done / experienced and learnt)
EG: I had loads of Powder on mine and the bolts kept coming loose / the engine was getting too HOT (When Racing) and the coating was not helping....
R
