944 Turbo S Engine Rebuild Thread
- Thread starter Eldavo
blade7
Well-known member
Ha ha, it's only been around 6 months since I went up and down my drive in it. I charged the battery and it fired straight up, and ran until the fans cut in yesterday. I'd only remove the compressor, think I've read the alternator sits lower and makes more room for a bigger turbo. Guess I'll take it to an A/C specialist and see what's involved to recommission the system first.Eldavo said:It is pretty heavy for what it is but I guess you wouldn’t notice the weight saving on its own. Obviously if you remove it, then the condenser, receiver dryer, lines, etc. etc. then you’re getting more weight loss and increasing your marginal gains but I do have 2 further thoughts on that:
1 - If we were good enough drivers to genuinely notice a marked difference by removing 1% of a car’s weight then we probably wouldn’t be driving 944s.
2 - By the time you get it out of the garage and try to compare it to how it used to be, that 3-5 year frame of reference might be a bit woolly now []
scam75
Well-known member
Anyway, my car obviously "just needed a re-gas" when I got it. Done a pressure test and the condenser was a sieve. Got a decent 2nd hand one and it worked. However it didn't keep gas long as the compressor nose seal had seen better days. New compressor sorted that. Fitted a new receiver/dryer as well. Only replaced the seals between the compressor and pipes and condenser and pipes. A smidge of ester oil in when it was refilled and it happily runs R134a. Did need a 3rd condenser when the 2nd one sprung a leak, they are in in a bad position and particularly vulnerable at the small inlet pipe, where mine fractured. With my latest condenser I have protect this with thick stone chip and so far so good, doesn't leak, and is icy cold in summer and a moisture hoover in winter.
Stuart
TTM
Eldavo said:Magnecor made me some custom leads, great company, great service and great price!
Did you actually paint in orange the bolts holding the plastic lead clamps? [
blade7
Well-known member
scam75 said:I went to the bother of getting my AC up and running a while back, it really is very good when it's working. Windows demist super quick in the bad weather. Suppose you don't have much bad weather in your garage Blade! []
Stuart
Oy, I'll have you know it's only seen bad weather 3 or 4 times outside of the garage in the last 14 years [
TTM said:Eldavo said:Magnecor made me some custom leads, great company, great service and great price!
Did you actually paint in orange the bolts holding the plastic lead clamps? []
When I had the cam cover powder coated red (ironically it was actually Orange beforehand) I put sacrificial bolts in all the threaded holes beforehand. When I got it back and removed them I realised that they were the perfect length for holding the plastic clamps in so it was meant to be!
blade7 said:Ha ha, it's only been around 6 months since I went up and down my drive in it. I charged the battery and it fired straight up, and ran until the fans cut in yesterday. I'd only remove the compressor, think I've read the alternator sits lower and makes more room for a bigger turbo. Guess I'll take it to an A/C specialist and see what's involved to recommission the system first.
Yes it is a very tight fit getting inlet pipework to the turbo with the alternator sat on top of the a/c compressor - especially with 3” pipework. I had to use silicon hose over that part as it allowed a smidge of deflection.
You could remove the compressor, receiver dryer, condenser and the 2-3 pipes that connect them.
blade7
Well-known member
Dan944t
looking really great
im also getting very close to finishing my build now… ( Diy full Holset hx35 twinscroll in and nearly finished custom 3” at back wheels now ,.. but lots more fabricating to go till i will be ready- but getting there now ! )
hopefully one day in summer we can all meet and have a good chat about our cars
atb
Daniel
Having a bit of chassis surgery too at the welder’s next week as one of the rear castor mount captive nuts made a successful bid for freedom!
Dan944t
i need to get prepared to weld nuts to my 986s headers as they are not looking great and i have nice custom headers for it ( not a nice job on your back welding straight up ) really need a ramp
blimey think it’s been near on 4 years ? i havnt drove my 944 turbo
Had the car taken to the welder’s today - should get it back in the next week or so. Recovery truck was ace, backed it up the drive, lowered the loading bed right to the garage door and winched it straight in - Magic!
I can almost forgive the Grocer’s apostrophe.
CBschnell said:David, do you have a link for the clips? thanks
Ordered direct from Porsche, about £7-8 each.
941.356.555.11
