Anybody booked for Donnington ?
Donington always uses the drive by method.Why mess about with static tests when they have gone to the trouble of fitting testing devices all around the circuit?[;)]
98dB is quite high for drive-by - should be OK with a 964RS, several there last year no problems.
ORIGINAL: ChrisW
I was recommended to bring 996GT3RS --- as a quiet day the drive by limit of 98dB will be applied --- and enforced ---
Guess that rules me out in a 964 RS. I am going to make a sound reducing tip but not sure if it will either be made in time or enough to get it down to 98dB. Usual reduction is 2 to 3 dB. May come along for some PAX rides if anyone offers.
Paul,
If I understand the other posts in this thread, it is 98db driveby, in which case a 964 RS should have no problem whatsoever. Although I must admit 98db driveby does sound extremely high, and wouldn't tally with the idea of it being a "quiet day". Anyway, I've paid my money, so will give it a bash and see what happens. I will make sure I have a little trick up my sleve to appease the noise nazis if need be ............. (which I will be happy to lend around should there be a problem with unexpected static tests .........)
Jamie
I had no issues with the drive by testing last time in my car.
At the time it had a knackered secondary silencer (as it has now) and I didn't get told off.
Hopefully be fine on the day.
Paul, my 105dB was with the sensor right at the silencer exhaust (Oulton RS day) and with the engine at 4750.
If the static sensors are a reasonable distance away, then there may not be a problem.
Does anybody have any dB comparisons ?
(And I'd prefer to take the '64).
You'll all be ok at Donny on the drive past.
Its only the 997 GT3RS's that get caught out!!!
ORIGINAL: jason
Agreed! Loads of RS's (964's) there last year and NO PROBLEMS[:)].
Thanks guys - you've talked me into it. Sending form in today.
Lots of 968 going apparently.
See you there.
Cheers!
Cinderella and her Ugly Sisters but we know who's going to the ball......... well Donnington anyway. See you on Sunday
Nick
See ya there Nick!
So here's the list so far:
1. ChrisW =Maritime Clubsport
2. Jamie Summers =Black RSL
3. Ian964 =Maritime Cup Car
4. 65 mat =Polar Silver RSL
5. Jason =Black/Orange RSL
6. Kasbridge =Ferrari Yellow RSL
7. 964RS =Rubystone Red RSL
8. DavidM777 =Amethyst RSL
9. Rob Hunslow =Red C4
10. Lowndes =Maritime Blue RSL
11. Oldtimer =Black RSL
12. Alexander Drobik =Blue C4 Motec
13. Tony =Red RSL
14. Nick Evans =Maritime RSL (RSR spec)
Quite a list guys! Any amendments or additions?[;)]
It's a shame you won't be driving Martin. Is your car out of action?
You are welcome to join me for a few laps but I ain't the quickest!
I'm hoping to be there in mine even though I'm not booked on track. However, I'll bring my helmet in the hope of a getting few p/x laps [;)]
Dear all,
For anyone else interested in one of Will's noise reducing exhaust tips, I will have two with me at Donny on Sunday - first come, first served ............. In addition I will have a working prototype of the extra noise reducing insert for the tip, which hopefully I will get the circuit marshalls to noise test for me on the day. Assuming all works to plan I can take orders for Will on the day. The idea is that the insert will be a push fit bung for the existing noise reducing tip which can be put in for static tests and then removed for actual track driving (as we know the 964 does not generally have a problem with driveby noise). Whilst it is not likely that it would cause damage to the engine it is highly recommended that the insert is removed before driving on track (manufacturer accepts no responsibility for damage caused if you don't etc etc etc). With any luck the insert should allow a 964 to pass even a 98db static test, so no track should be inaccessible any more (or even in the future). By way of evidence, an earlier prototype was tested at the Oulton RS day in March, and reduced a 993 Cup Car from 114db static to 100db static !!!!
Look out for me on Sunday - black RS reg J500 RSL
see you then .......
Jamie
