MrDemon said:
I forgot about the painfull oil heat up time in the 981 and VERY bad MPG. my 981 GT4 and Spyder are some of the worse cars I have owned for mpg and the oil heat up time is daft, so trips to the shops or anything under 6 miles is going to damage the car and have the car rotting from the inside out.
The rides not a patch on the 718 also, and remember the 718 is more GT4 and more GT car with fully adjustable shocks LCA and GT brakes
the noise while loud don't suit the cars and coffee nature of the car either, so you take the other half to the cotswolds for tea and when you over take any car it's embarrassing I thought. The Asbo sound did not match the lifestye drive. YOU cannot turn it off as it opens the valves if you hard WOT so people do think you are a bit of a **** in the cotswolds if you have to over take. Sadly the 981 GTS also pops and farts. The 981 GT4 sounded great.
Great points Mr D even if totally exaggerated and contradicted by Mr Catchpole:-
20' Today so off on what is very close to summer Spyder driving
4.2 Miles and oil level was showing 3/4 full ie normal level when warmed, the oils temp at this time was 90c
7.2 Miles and temp was fully warmed to 102c
For the record and rarely breaking the speed limits I manage an easy 21-25mpg around town or short 10 mile runs
Quick blast like todays 35 miles equaled a very reasonable 28.4 mpg
Faster longer runs on A roads or motorways I can get 31-34mpg say 50 plus miles
The far more brittle ride on both my previous 987 Spyders weren't a patch on my 981's and as Henry rightly says "it rides very well"
A point not mentioned above was the 987's optional short shift gear change excellent as it is IMO isn't as good as the 981's standard very short shift
The noise isn't loud compared to supercars and if its too loud for some there is always the option to use the off switch to bring it back to very subdued levels below 4k rpm which is mad speeds in any gear bar maybe 1st and no audible pops and bangs on the overrun (PSE OFF) to frighten the horses but as Henry says "it sounds phenomenal" when ON and something a 718 Spyder can;t come close to replicate IMO with a JCR or equivalent £5k +++ box
Finally, unlike Mr D who clearly favours the GTS version, Henry states the 981 Spyder is the best model in the 981 range and "lifts it above the GTS" clearly demonstrated by the residuals today
IMO all Spyders are winners 987/981/718 and which one suits you best can be found with test drives if money isn't the key fact and if it is then go for the cheapest version the 987 Spyder and enjoy each mile as it won't disappoint
Enjoy the video from a man who knows his cars [link=https://www.youtube.com/watch?v=R_Bmi-2Yk20]Porsche Boxster Spyder | evo DIARIES - YouTube[/link]
