It's a bit sad that such a usable car has so few miles. There is nothing "high days" about the Spyder - fundamentally it's still a Boxster and that's one of the most practical, usable sports cars on the market. It must make the £/mile eye-watering to use the car so little!ORIGINAL: spyderwhiteI have just turned 2000 miles in under 2 years and she had her 1st service this week 2 months ahead of scheduleORIGINAL: daro911My brother's April 2011 1000 miles exactly[ORIGINAL: Siy so what's the lowest mileage one (in use ... ie not put aside with 12 miles on it and waiting for 20 years!)]
- Thread starter daro911
I have a early car car and it's on 8k miles :-( or
which ever way you think about it. But to combat that I have done another 6k in the R already, so better those miles put on the R than the Spyder. those disks look great value but I think if I were buying after market I would up up size to 350mm from 330mm as on my R they look tiny when sitting next to my PCCB's. Not sure why buying the PF disks is much of a upgrade, same size, still drilled and not slotted so I doubt there would be any performance change. if keeping the same size I would just fit a set of £150 Sebro disks, it will work just as well and cheap to change, there new sport design is also slotted.
![611075d1330227121-sebro-slotted-sport-rotors-availible-sport-slotted1.jpg](http://forums.rennlist.com/rennforums/attachments/racing-and-drivers-education-forum/611075d1330227121-sebro-slotted-sport-rotors-availible-sport-slotted1.jpg)
I read the PF disc bells catch all other branded pads though so you have to use PF pads also. Floating is not all that, and you still change the bells every other disk swap out as the holes can wear or every 3rd disk max. The top UK GT3 CUP race cars use oem 1 piece disks and just change them every race as they are cheap. I still don't see any performance advantage paying £600 over £150 for a set of 318mm drilled disks bar looks. at £150 a set you can just swap them out when a little worn and it's a non issue. only way to get a performance increase is too either upsize disk size and fit spacers, or buy PCCB 6 pots calipers and then steel brembo 350mm replacement large disks. so I would say any thing inbetween is not worth spending money on esp £600 on. I think only Giro sell a upsize kit with spacers which take them, from 318mm to 340mm. the PCCB are still bigger at 350MM and as I said buying the PCCB calipers and then fitted the Brembo 350MM steels 2 piece steels would be the ultimate upgrade. of course imho ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
whilst its great to enjoy them unfortunately the down side of such an exlusive rare car is that the mileage is the single most important thing (imo)that affects resale value. with only 230 odd cars built a car with 40-50k miles over 10 years will prob be worth double one with even less than average miles .this is what has happened to most low production porsche over the last 30-40years (on the whole). if and when i get one though,i intend to drive it [ORIGINAL: spyderwhiteI have just turned 2000 miles in under 2 years and she had her 1st service this week 2 months ahead of scheduleORIGINAL: daro911My brother's April 2011 1000 miles exactly[ORIGINAL: Siy so what's the lowest mileage one (in use ... ie not put aside with 12 miles on it and waiting for 20 years!)]
Are the 6 pot calipers the same mounting or is it a different hub? I thought the bolt pitch centres were different [&:]ORIGINAL: MrDemon I read the PF disc bells catch all other branded pads though so you have to use PF pads also. Floating is not all that, and you still change the bells every other disk swap out as the holes can wear or every 3rd disk max. The top UK GT3 CUP race cars use oem 1 piece disks and just change them every race as they are cheap. I still don't see any performance advantage paying £600 over £150 for a set of 318mm drilled disks bar looks. at £150 a set you can just swap them out when a little worn and it's a non issue. only way to get a performance increase is too either upsize disk size and fit spacers, or buy PCCB 6 pots calipers and then steel brembo 350mm replacement large disks. so I would say any thing inbetween is not worth spending money on esp £600 on. I think only Giro sell a upsize kit with spacers which take them, from 318mm to 340mm. the PCCB are still bigger at 350MM and as I said buying the PCCB calipers and then fitted the Brembo 350MM steels 2 piece steels would be the ultimate upgrade. of course imho![]()
Dyllan You are right upto a point - however, once past a certain age a car with reasonable miles on it in A1 condition will be of more value in the market than one with lower miles that has not been looked after either cosmetically and/or mechnically. Condition tends to be King once a certain age is reached!ORIGINAL: dyllanwhilst its great to enjoy them unfortunately the down side of such an exlusive rare car is that the mileage is the single most important thing (imo)that affects resale value. with only 230 odd cars built a car with 40-50k miles over 10 years will prob be worth double one with even less than average miles .this is what has happened to most low production porsche over the last 30-40years (on the whole). if and when i get one though,i intend to drive it [ORIGINAL: spyderwhiteI have just turned 2000 miles in under 2 years and she had her 1st service this week 2 months ahead of scheduleORIGINAL: daro911My brother's April 2011 1000 miles exactly[ORIGINAL: Siy so what's the lowest mileage one (in use ... ie not put aside with 12 miles on it and waiting for 20 years!)]
ORIGINAL: billy1 There is nothing "high days" about the Spyder - fundamentally it's still a Boxster and that's one of the most practical, usable sports cars on the market.
Thumbs up for that noise in the tunnel[ORIGINAL: rob.kellock What a waste! I've taken mine to Le Mans. Roof down as often as possible when it wasn't really raining. It was brilliant. http://s1219.photobucket.com/user/robkellock/media/29b9c4db.mp4.html?sort=6&o=631
spyderwhite
I never intended to do such low mileage its down to a broken foot and other commitments.actually £/mile is still very cheap for me,excluding depreciation the car has cost me lot less than a pound a mile!ORIGINAL: billy1It's a bit sad that such a usable car has so few miles. There is nothing "high days" about the Spyder - fundamentally it's still a Boxster and that's one of the most practical, usable sports cars on the market. It must make the £/mile eye-watering to use the car so little!ORIGINAL: spyderwhiteI have just turned 2000 miles in under 2 years and she had her 1st service this week 2 months ahead of scheduleORIGINAL: daro911My brother's April 2011 1000 miles exactly[ORIGINAL: Siy so what's the lowest mileage one (in use ... ie not put aside with 12 miles on it and waiting for 20 years!)]
i agree to a certain extent John-mileage AND condition clearly are both imprtant and an older car with low mileage thats been abused wont fetch too much( unless its a rare barn find classsic!!!!) however i was assuming we all look after our cars like you and i do so if both in similar condition ,i still think the mileage below 40-50 k may even as much as double the vaule ocer time ..i dont know the future obviously,but i wouldnt be surprised if spyders with 40-50k or less miles will be worth close to what they are now in 5-`10 years time while those with higher may well be half or less.-just my thoughts . i know when i came to sell my immaculate 89k miles 993 at 15 yrs old i got only 2-3k more than failry scruffy examples but only 2/3 what a car with 5-60k miles were fetching.I know there were far more 993`s produced but a similar kind of argument I thinkORIGINAL: jdpef356Dyllan You are right upto a point - however, once past a certain age a car with reasonable miles on it in A1 condition will be of more value in the market than one with lower miles that has not been looked after either cosmetically and/or mechnically. Condition tends to be King once a certain age is reached!ORIGINAL: dyllanwhilst its great to enjoy them unfortunately the down side of such an exlusive rare car is that the mileage is the single most important thing (imo)that affects resale value. with only 230 odd cars built a car with 40-50k miles over 10 years will prob be worth double one with even less than average miles .this is what has happened to most low production porsche over the last 30-40years (on the whole). if and when i get one though,i intend to drive it [ORIGINAL: spyderwhiteI have just turned 2000 miles in under 2 years and she had her 1st service this week 2 months ahead of scheduleORIGINAL: daro911My brother's April 2011 1000 miles exactly[ORIGINAL: Siy so what's the lowest mileage one (in use ... ie not put aside with 12 miles on it and waiting for 20 years!)]
I didn't [original: flat6 Everyone tells me to keep it as it will be go up in value.
I missed out a couple of important words. Now added.
ORIGINAL: flat6 My personal motto is that whilst I cherish my car, it's not going to have an easier life than me, tucked up in bed half the year whilst i'm out driving. I also don't intend for my car to be in a better state of health (read mileage) than me as I get older[]
Equally good point. 15 years - can't see me having it that long. There'll be other cars i'll want to try in that time and I couldn't afford to keep the Spyder alongside them[&o] My Spyder is my daily driver and is on 19,000 miles like yours. It's so usable. If I switched to something like a 4C, that couldn't be a daily driver IMO. It's more impractical than the Spyder. The front end doesn't open i.e. only has a small rear boot. I expect the engine noise in the cabin is immense. But the Spyder is just perfect. I'm used to the wind noise now and it's proven to be weather proof. The only thing wrong with the design is that I cannot fit some roof bars to it [ORIGINAL: rob.kellockI didn't [original: flat6 Everyone tells me to keep it as it will be go up in value.] You make a very good point. There are powerful arguments to suggest the Spyder has many of the ingredients of desirable cars like the 964 RS - bit unloved upon launch, less weight, more power, sporty bits and added bonus of bespoke bodywork. Will take at least 15 years for values to go up instead of down though.
Thought that was a Spyder with sports suspension button and then I noticed the instrument binnacle.ORIGINAL: daro911Wonder how many Spyders are out there with say 36k miles plus[&o]ORIGINAL: rob.kellock Ahem - should rack up 19k by the end of the weekend. It is ridiculous that at just 3 1/2 years old, that is high mileage for a Spyder [8|]![]()
Are most of those miles on the track or getting to the track[[ORIGINAL: MrDemon I thought I would do many more miles than I have. But less than 2k miles in close to 2 years.
![15054d1285415146-first-2011-boxster-spyder-racecar-_9103361.jpg](http://www.planet-9.com/attachments/987-cayman-boxster-competition/15054d1285415146-first-2011-boxster-spyder-racecar-_9103361.jpg)
nope
cars only done about 200 miles on track. Not really into track days any longer. If I go to one 4 x 5 laps is enough, it's more a day out and a bit of a play/meet up etc I am very easy on my cars. I also find making a car geo work for track is no good for the road and I do many more road miles, so any track days is always a compromise on set up. I get more of a buzz on a fast B road.
That surprises me after your previous postORIGINAL: MrDemon I get more of a buzz on a fast B road.
[&:]ORIGINAL: MrDemon But I would rather do sprints than hill climbs
