Hi dan
I am still using the standard manifold, I had planned to upgrade this for the SFR pipe but decided it wasn't needed for the power planned. Back pulses will still be there... Porsche designed the system so that the turbo outlet is smaller than the downpipe anyway, it still is with a 3" and then flows freely having just the one step from turbo to downpipe. If adding a 3" system and leaving the downpipe standard you now have two steps, turbo to downpipe and downpipe to exhaust pipe. This for me is not beneficial to good flow, perhaps better off just keeping the standard exhaust, I say perhaps, not being a velocity/flow /volume expert, although I do have friends who could tell me exactly the characteristics of a given setup.
Turbo's in any form are not cheap and of course, with more modern turbo's things get more expensive. Here's a link to the guy on FB for his voodoo turbo, he's well respected in 951 circles. [link=https://www.facebook.com/photo.php?fbid=10222036504236791&set=pcb.3357513437605569&type=3&theater&ifg=1]https://www.facebook.com/photo.php?fbid=10222036504236791&set=pcb.3357513437605569&type=3&theater&ifg=1[/link]
A good performing engine needs a lot of things to add up, you need to match the CFM as best as possible and the turbo to be above that figure. So headwork, intercooler, pipework, inlet etc etc, there will always be one part that restricts but despite what you may read, the 951, in general, isn't bad. Duty cycle is controlled by an electronic solenoid which holds the boost. So 0% duty cycle means no solenoid operation and relies purely on the wastegate spring, you can fit a stronger spring (I have a 4.5mm spacer which I machined to increase spring pressure in my wastegate and used a new spring and diaphragm) but this doesn't give you everything that you need and too strong a spring is bad. The solenoid which you control from your EBC will hold the boost at the level you set, however, if you set the duty cycle too high you will get boost spikes. The higher the duty cycle the better the response from the turbo (you still need a good spring), I can't recall the average duty cycle setting as recommended for boost setup by my Apexi, maybe 35%. From that point, you then drive and test how the turbo responds if it's taking too long to spool for your liking then try increasing the duty cycle. I used to have mine at 85%, I reduced it a little to 80% when the larger injectors were fitted and ignition was recently changed. I have noticed a slight drop in response but nothing much, I will probably increase it again soon when happy all has settled in, BTW my son has his cossie duty cycle with his massive turbo set at 100%, but then he's mad. even with that duty cycle his turbo still takes time to spool up, as I tease him on when I hear him trying to get on boost while coming down my close, you know how short that is...
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
As a safety, I have a stepper boost gauge that gives me an audible warning at a set boost level, this is to warn me when the boost goes above what the EBC has been set too, which it will as a matter of course with a high duty cycle set. I then know to back off a little to reduce the spike. having the Vitesse MAF+ I have the added security of setting a boost level for the ECU too so any spike above 1.5BAR is very short-lived, the engine as built will cope with higher levels than that anyway.
I'm not very familiar with Tial but do recall reading that you want the larger size for big power, I don't think that the 38 will achieve the power you want? I stand to be corrected if I have this wrong.
Pete
