PSH
I didn't find the time to get as much done as planned this weekend but I did get one important job out of the way, replacing the rod bolts. The preferred method for doing this would be to use a suitable hydraulic press, I sold on my 40 ton press some years ago due to space and didn't fancy driving up to my son's garage to use his. The alternate method which is probably how most DIY mechanics would have to do it and therefore worth going through here is to drift the bolts out. First picture for tonight shows No.1 rod ( I tend to do things in order), you need a good vice for this. As can be seen the rod is held securely between two pieces of 3/4" plywood, I used this as it can be compressed enough so that it grips both the big end and little end thus supporting all of the rod, the little end is not as wide as the big end. Once held securely a couple of sharp taps followed by lighter ones enabled the old bolts to be removed. All four rods were done in this way.
Next job is to fit the new bolts ( Raceware of course), the rod is now held upright in the vice still sandwiched between the ply, I first placed the bolts into the rod ensuring that the spline is engaged correctly. Then using a brass drift and hammer I tapped them home, this sounds easier than it actually is, you need to use pretty heavy taps to get the bolt fully home which it must be,I don't like to rely on the bolt being pulled in alone by the torquing procedure in case you overstretch the bolt. In the picture you can see one bolt fully engaged with the second being tapped home.
Ok, so all bolts are now fitted, next we need to refit the bearing cap( without bearing shells) and torque it down to the specified setting, again there are two methods for doing this with the preferred option being the stretch method. I wouldn't like to rig up something using my dial gauges as the amount of stretch is very small and needs the correct tools to be sure you get it right. So again I am forced to use option 2, that being the traditional torque method. The torquing procedure has 3 steps, 25ft/lb,45ft/lb and finally 65ft/lb, the threads must be oiled using 40/50 oil, no other or you won't get the correct torque. This is done twice( a 3rd and final time will be when refitted to the crank) to ensure the bolts are fully home, each time make sure the threads are clean, re-oiled and re-torqued following the 3 steps mentioned.
Before we can say that the rods are ready we need to check that the big ends are still round as it's possible for these to get out of round during hard use or during new bolt fitting. I couldn't find the measurement for this in the Porsche manual, it only gives the journal sizes but I was happy to discover that all 4 rods when measured across two axis at 90 degrees to each other are identical and all four rods measure within 0.01mm of each other. This is very good news as I don't have to go back to Serdi's to get the big ends re-machined round. This is testament to just how strong these Porsche forged rods are, I doubt very much if using the later non forged rods and running for a number of years with a 75% increase in power that they would still be the same shape and therefore would require some machining to rectify the problem.
Final picture for tonight shows all four rods with their caps correctly torqued ready for fitting later, I'll leave them like this until I'm ready to re-fit the new pistons and install in the block. Note the old rod bolts alongside, I'll keep these as they are perfect for holding work down to the mill bed, as are the old wrist pins for using as parallels, again very handy for milling.
More soon Pete
