Your explanation is so much better than mine Jon, as George said I hope your back recovers soon..
Oil cooler housing or for a Turbo Oil filter housing as the cooler is separate, whichever you have both need to be aligned correctly. I'm not one for spending money when I can make something to do the job myself so after a short while on the lathe I produced this home made alignment tool. The narrower end is a slide fit for the OPRV guide fitted in the block and the other end is wider to be a close fit in the threaded section in the housing, made from alloy so as not to damage anything.
Before refitting the housing I needed to replace the main facing gasket along with the two 'o' rings on the connecting tube. As I have done every stage of this build I first did a little R&D on this, Porsche improved the connecting tube seen in the picture and also had a bulletin advising the use of Loctite 638 to help hold a washer in place if the recess for it measured more than 14.2mm deep. Not knowing what tube I had fitted or if it was sealed with loctite I first used a depth gauge so I could record the amount of tube protruding from the block, so I would know if I had refitted it correctly.
The manual says to remove it by hand but if stuck to wrap it in cloth and use molgrips to pull it clear, I had to use grips. Looking at the state of it I'm not surprised that it wouldn't come out by hand, you can see that the inner seal has failed evident by the hardened black crud around the tube. BTW this is the later tube that Porsche fitted so at some point in time this part has been updated, you can tell by the fact that the tube seal recesses are equal-distant from the ends, the early version had one seal closer to the one end than the other.
Tube fitted with new seals, I first cleaned off the crud that I could.
This is the inner face of the housing with the new gasket in place, when I first took this off it was obvious that a sealant had been used along with the gasket when last done, not wishing to risk a leak I also applied a small amount of Loctite gasket sealant to ensure it would remain dry.
Next was to refit the housing, this is done by first loosely fitting it ensuring that the gasket is in it's correct position, then before tightening insert the alignment tool to ensure the housing lined up properly for the OPRV and torque the four bolts to 14ft/lb. Now after doing this the alignment tool should easily pull clear, mine didn't meaning it was still a fraction out. Although you couldn't feel any difference I slackened the bolts and re-torqued them being extra careful to do so in small steps. This time the alignment tool easily slid in and out of the hole , no binding whatsoever so I'm confident the housing is now positioned correctly.Picture shows the alignment tool protruding from the OPRV opening.
This is the 3 piece OPRV, I have decided to keep this for a number of reasons, mainly that the replacement OPRV for an 86 turbo is a ridiculous price and also the fact that it worked well perfectly before and I can see nothing to indicate that it will not do so again, plus I like the simplicity or it that can easily be reproduced if needed by myself.
Finally as usual a reference picture to show work so far.
Pete
