Building a 400bhp+ 2.5 ltr 944 Turbo
- Thread starter PSH
Nothing special, just a good clean and decrease as you said. The paint is designed to go straight onto bare metal without the need for primer. Regards PeteORIGINAL: Hairyarse Thanks Pete, did you need any special prep for it or just a good clean and degrease?
Thanks Rob I have to say I'm enjoying it so far, I think the fact that I'm not in a hurry helps as I can do the little things that normally may get put aside. Got a long way to go yet though, I do hope that the pictures help others like yourself doing the same job in the future, personally I find seeing something like an engine in bits helps greatly in understanding what the thought process was of the original design, once I understand that everything tends to go a lot smoother, onwards and upwards..ORIGINAL: robdimond Pete, Love your thread, thanks for taking the time to write up and post the pics. I even read updates on my phone when on holiday which is more than a tiny bit sad! Hope to do the same myself one day... Rob
![IMG_2960.jpg](http://i1015.photobucket.com/albums/af276/944turbo1/IMG_2960.jpg)
![IMG_2959.jpg](http://i1015.photobucket.com/albums/af276/944turbo1/IMG_2959.jpg)
![IMG_2964.jpg](http://i1015.photobucket.com/albums/af276/944turbo1/IMG_2964.jpg)
![IMG_2965.jpg](http://i1015.photobucket.com/albums/af276/944turbo1/IMG_2965.jpg)
![IMG_2966.jpg](http://i1015.photobucket.com/albums/af276/944turbo1/IMG_2966.jpg)
![IMG_2967.jpg](http://i1015.photobucket.com/albums/af276/944turbo1/IMG_2967.jpg)
![IMG_2968.jpg](http://i1015.photobucket.com/albums/af276/944turbo1/IMG_2968.jpg)
![IMG_2969.jpg](http://i1015.photobucket.com/albums/af276/944turbo1/IMG_2969.jpg)
![IMG_2970.jpg](http://i1015.photobucket.com/albums/af276/944turbo1/IMG_2970.jpg)
![IMG_2976.jpg](http://i1015.photobucket.com/albums/af276/944turbo1/IMG_2976.jpg)
As a tip, the spigot bearing can be removed by filling the recess in the crank with gease and then tapping in a correct size drift or old first motion shaft. As the drift goes in, the grease will push the bearing out. [ORIGINAL: barks944 Looks good, boy I wish I had that tool to remove spigot bearings![]()
Genius!ORIGINAL: LancerlotAs a tip, the spigot bearing can be removed by filling the recess in the crank with gease and then tapping in a correct size drift or old first motion shaft. As the drift goes in, the grease will push the bearing out. [ORIGINAL: barks944 Looks good, boy I wish I had that tool to remove spigot bearings![]()
] Regards, Clive.
CarreraRSR
Ford jubilee clips!!ORIGINAL: PSH Just one picture for tonight.. I finally received the silicone reducer elbow that I ordered from Performance Silicone Hoses, the size is 12mm x 19mm id's. I cut the old hose leaving the swivel part of the original still attached to the metal downpipe, this was where the 19mm end fits with the 12mm end fitting to the AOS.Another piece of the puzzle done...![]()
Pete
haha... yes had to use an old one for that end...hadn't realised that it was a ford jc... must be one of my son's,,,, Ooopss PeteORIGINAL: CarreraRSR Ford jubilee clips!!
George Elliott
![IMG_2989.jpg](http://i1015.photobucket.com/albums/af276/944turbo1/IMG_2989.jpg)
![IMG_2988.jpg](http://i1015.photobucket.com/albums/af276/944turbo1/IMG_2988.jpg)
