I have been working with Dave throughout this period and can assure you that the club is trying its hardest to engage with Porsche. The Chairman has written directly and is pushing for a reply but, if Porsche wish to just deal with this, through their OPC's, on a case by case basis and not talk to the club about it, there is not a lot we can do. The overall numbers are small and, as has been stated before, if the issue had just been fixed under warranty we would all have moved on. As a club, our priority is to look after and support its members. Every case we have come across has received that support and has been, or is currently being, successfully dealt with.
As Dave has pointed out, we have a number of specific issues we are continuing to chase down:
The GPF is not blocked - wrong diagnosis
The Differential Pressure sensor can be faulty giving false readings
There should be a regeneration warning which comes on before it gets to a CEL. This system is inoperable.
Numerous examples of appalling service, mis-diagnosis and, potentially, overcharging
Claiming that the GPF is a service item when it is not referred to in any service schedule, check, or the handbook.
Producing (VAL) reports which clearly dont make sense.
Claiming that the car is fit for purpose whilst saying that there are types of driving that cause the GPF to get blocked
Being unable to conduct basic tests, such as AOS function, exhaust back pressure etc. which are cheap to do and would either corroborate or contradict readings.
Remember, we are dealing with Porsche OPC's here who can only evaluate what shows up on the car dashboard, PIWIS tester and diagnostic system, usually by changing out successive bits until the warning light stays out after the reset. But I feel sorry for the OPC's as they can only work as instructed by Porsche. However that does not excuse the way some OPC's seem to treat their customers.
We are trying hard to bring this to a conclusion.
John
