angusc
Yes ditto, ditto......... I started removing my cats and headers two days ago. My cat bolts were almost non existent and the nuts had corroded to points of steel. I used a hammer and large punch to hit the bolt ends and this luckily allowed them to release the remaining corroded nuts. I removed the CAT pipes complete with oxygen sensors firmly seized in place. The header bolts were a major concern, as new the bolt heads are 13mm AF only a few of the total 12 bolts still had 13mm AF and others were 12mm and incredibly down to 10mm on one! I used a six sided socket set and was able to release all bolts without any shearing off....phew!
The chrome header pipes went on yesterday but I had to ordered a replacement tandem pump as the original was also badly corroded and needs replacing before the X-Pipe gets fitted.
The oxygen sensors are proving a challenge to get out from the original cat pipes. Today I managed to heat up the socket nuts and removed two of the sensors from the right hand side pipe, but the nearside pipe is more challenging. I will tackle that one tomorrow.
Hopefully tomorrow my new tandem pump arrives at OPC and I can crack on.
