penguinman said:I can add to Steve's experience with PS4S's, fitted to 981S, at Brands Indy circuit, dry but a little cold, back in late March. Totally agree, after a couple of warming laps (me, tyres, brakes), they felt instantly better than the P Zero N1's. Turn in particularly good, and I was a happy panda. But, Like Steve, after 4 or 5 quicker laps, they went off almost instantly, like a switch. Turn in grip lessened, and slidey mid corner similar to Pirellis.
I started on 30psi all round cold , and checked on coming in they were over 40. Reduced to 37 all round hot, went out later and had same experience.
On GP circuit next week, be interesting.
why did you only reduce to 37PSI !
I start out on about 26psi, any lower can ruin your tyre, then only do 2 laps and bleed down, then another 4 and bleed down, and that's normally that. I then pyro to fine tune to try and get and even temp across the tyre. any way PS4S is a road tyre and why it's so good on the road/and wet track is it's very easy to get heat into it for road use, As always choose right tyre for the job which means for a dry track the Cup2 which takes 2 laps to get to temp.
Most road tyres will not do more than 4 or 5 laps, my P zero's went off in 2 laps when I used them I gave up and went home !!!
5 laps is quite good imo if you are on it.
I ran Dunlop Race MAxx at Spa It would only do 1.5 laps before going off, the ****test track tyre ever and were sitting at 65 degrees+ I have ran PS4S all winter on the road and they have been amazing tyres, I have 2 cars on PS4S and 2 on Cup2's.
Always have 2 bleed down sessions as if you get them too hot they will heat cycle and go off 1/2 worn making you wonder why on tyres with 4mm tread why you are unsteering every where.
