craiginuk said:There was a group buy a while back (I think in Rennlist). They modified the fastening mechanism. Something to do with loctiting the fasteners in place as they were coming loose. I think this is the modification they are carrying out on the remaining units. Am sure all will be fine. It's not like we have paid up front.
Exactly right. When Pilkington remade the units for the US buyers they found that after a few weeks of use they started to generate excess wind noise. This was down to the material used for the clips that hold the front of the unit into the roof panel. I believe they were made to original spec and that's why the originals all suffer with this problem. At no cost to the guys in the US, Pilkington devised a modified system that could be retrofitted to the new units. From then on, all Saratoga Tops were to be dispatched with this system rather than the original. Because this order is larger than they first predicted, not all of the stock units have this modified set up on and they have had to order all the parts and make sure they are suitably fitted.
It's all in the Rennlist forum thread: [link=http://rennlist.com/forums/944-turbo-and-turbo-s-forum/680660-pikington-will-make-saratoga-tops-again-86.html]http://rennlist.com/forums/944-turbo-and-turbo-s-forum/680660-pikington-will-make-saratoga-tops-again-86.html[/link]
Appreciate it's a simple mod and any schoolboy could do this in under 2 minutes but it's not worth worrying about. Have faith, they're coming!
