Something i have been working on!
- Thread starter MarkK
MarkK
Well-known member
MarkK
Well-known member
pauljmcnulty
they punched in the chassis number and it is due a recall- a check on a fuel line...bit late maybe?
Good to see a system working as it should! [&:]
MarkK
Well-known member
I did ask them if they had a broom handle handy,they looked confused( i then explained they would need it to hold the plastic bonnet open[
MarkK
Well-known member
Mike
PSH
Great car Mark... A question on the fuel line recall... when was this issued.. surely our cars won't be covered.. is it just an advisory or an official recall where Porsche replace the item FOC. Failing this does anyone know how much a replacement costs and what part number to use?
I ask as I have just bypassed (today) this line temporarily due to it looking very worn with cracks in it, for now I have connected the damper fuel line directly to the fuel rail, of course this is not statisfactory with pulsing felt threw the fuel lines due to not having the damper connected but much safer than having the line fail resulting in a fire and lost car...
Pete
MarkK
Well-known member
sawood12
ORIGINAL: MarkK
The recall system or the fuel system??Its weird the whole recall thing its a 1988 car and its 2010,why would they bother?The fuel lines have been checked recently alot so i know they are ok,its just a factory check they have to do with any cars passing through the dealer network i bet..
I did ask them if they had a broom handle handy,they looked confused( i then explained they would need it to hold the plastic bonnet open[])
If a fault has been identified either by a design flaw or by a manufacturing batch issue, then Porsche has a duty of care to advertise the fact and make the repair available to all for ever or until such time that Porsche can prove that all the cars at risk have been subjected to the inspection or replacement - or until such time they can prove all cars have been scrapped. In the event of the worse case happening as long as Porsche can prove it has done all it reasonably can to mitigate/fix the issue then they are legally covered.
MarkK
Well-known member
