IT LIVES!!!!!!
Nothing is ever straightforward though, there was a crack in the bracket that holds the fuel dampener onto the rail. Pressure tested the rail and it was fine so had it welded up and a couple of strengthening bits done too. I have a spare rail so will get that strengthened and then powder coated at some point this year and fit that one.
Ran up to temperature until the fans came on and then fully bled the system, put a bit too much coolant in but the overflow will take care of that no doubt. Hydraulic lifters were silent so I definitely dodged a bullet there - either through good luck or good oil (Royal Purple) but I'm sticking with the same oil and hoping for the same luck.
Aiming to pick it up tomorrow if I can get a lift to the garage and then take it to our regional club night on Weds - although last time I went to a club night this happened!
First Trackday is in a month's time, with having had the rod bearings changed are there any precautions or running in procedures to consider?
