Turbo Engine Rebuild
- Thread starter scam75
scam75
Well-known member
Get it back later then need to swap over the temp gauge for my spare one as it's been going mad and change over the trim that houses the clock and hazard switch as the hazard switch has sunk into the dash board (luckily I have a spare trim and switch)......then i might put on my shiny new set of wheel nuts as a finishing touch. Exciting!
Stuart
blade7
Well-known member
No slight was intended, and for what it's worth the colour, sunroof delete and wheels on your car are pretty close to my ideal spec. And no doubt the paint is better than on my car now. I still reckon the ride height is too low thoughFair enough, it's easy to get defensive with all the time and effort I've put in lately with engine and body work!![]()
scam75
Well-known member
As you will be well aware, it would need re-indexed at the rear, a job I have not undertaken yet nor have the appetite to do any time soon! It's something I will do eventually to coincide with a suspension refresh once I've had a couple more years out of my newly refurbed GAZ Gold units.
When I last had the geometry set-up done, I asked if they could lift it a little on the rear eccentrics, but there was next to nothing available to use.
Stuart
scam75
Well-known member
Having been there, done that, I was very glad that I didn't need to drop the entire rear subframe again to reindex it after my recent rear end refurb. It measures the same both sides to the top of the wheel arch, I did it by eye and some strategically taken photos before I took it apart. It is however a real PITA trying to get the torsion bars back into the housing in the right position and that is with everything refurbished and new bushings... If it needs adjusting, I will leave it to the suspension guys when I eventually get it all aligned.It is too low, I concur. You do get used to taking speed bumps at 3 mph after 15 years.....
Stuart
scam75
Well-known member
Huge shout out for my paint guy who kept to his original quote when things went way above and beyond the original estimate, and also paid the spark and the window guy, as well as fitting the valance support and bonding hockey sticks and doing the full sides stone chip that were not mentioned at the start. And doing a fab job. Happy days.
scam75
Well-known member
I can’t believe I’m saying this of all people . . . . but it looks a bit low!
I think the angle of that side on picture, with water underneath after a wash, makes it look a tad lower than it is. However, it is too low! I've yet to tackle lifting it a bit as it needs re-indexed which I'm sure will be a proper pain in the chuff. It was re-indexed before I bought it. In 15 years and 77k miles I've become accustomed to it however, speed bumps are not my friend. Them aside, its honestly absolutely fine.
blade7
Well-known member
Stick some height adjustable coil overs on the rear, and you wont have to reindex to raise the height.
scam75
Well-known member
Really, I was not aware of that, that is good to know!
I'm planning a suspension refresh in 2/3 years time. GAZ have promised me a really good deal when the time comes. I've just had both front shocks fixed with new rods and a service so want to get a couple of years out of them before my next move. I will consult with them about height adjustable rear coil overs. Despite my issues with the front dampers the rears are going strong after 13 years, although corrosion will end up being the death of them.
Stuart
blade7
Well-known member
scam75
Well-known member
