what did you do to your 944 today
- Thread starter colin944
scam75
Well-known member
Yeah will get a nice shiny solution soon for my vac lines. The plan is to get to Germany with you guys. I am juggling a new child though and already got a week's golfing in Spain with the boys booked for March. Mrs Scam will need bringing round to the idea, I am just the man for the job! What is your idle AFR? Mine was in the 16's with a vac hose loose and also caused it to run lean under load. Mine idles at mid 13's with vac hoses attached correctly and high 11's at WOT. Promax L2 chips as you know. I think the display on my AEM is just right, have you been to specsavers?! [8D] StuartORIGINAL: Frenchy Scam, get some nice new shiny hoseclips the crimp type for those vac hoses, fitted an AEM Digital boost gauge to my car today , only showing 13 psi on WOT so a quick check that i have no kinks in the vac hose which is directly off the manifold and a wee tweak is in order (read turn boost up to 17 psi) nice bit of kit but would have been nicer with a bigger digital readout compared to my innovate AFR gauge which has nice big digits. Sitting on axle stands now with the handbrake getting adjustment tomorrow, whilst in there i will be gunking and pressure washing the gearbox/diff. Stu, you coming to Deutschland in May ?
jonnyporsche
scam75
Well-known member
Via AFM adjustment you mean Jim! AFM = standard barn door affair, MAF = aftermarket solution that lets in more air and improves driveability across the rev range to name but a few improvements!! Don't want to open a can of worms but I would richen that a bit at idle. I run mid 13's on my chips and the boys at Promax reckon that's spot on. Which is just as well as I can't adjust it!! I put my idle speed up to 900rpm yesterday, had been at 800rpm for as long as I can remember. What do others have their idle speed at? Cheers StuartORIGINAL: Frenchy Top lad keep him learning ! Stu adjusted my tick over AFR to 14.6/7 via MAF adjustment took the black car out for a run and went and fired the 220 up to let it warm up.
scam75
Well-known member
TTM
Well-known member
Frenchy's post makes me think that the TPS may not be adjusted correctly? Does it click when it should?ORIGINAL: scam75 It could be my SciVision or the maps on the chips causing it.
scam75
Well-known member
I think so, but will check and confirm tonight. I'm still having the odd vac issue too, every now and then the revs will dip a way down to about 200rpm then catch when clutch is dipped. 99 times out of 100 it's ok and doesn't do this. I am going to take all the vac lines off tonight and inspect them then secure them with little tie wraps. StuartORIGINAL: TTMFrenchy's post makes me think that the TPS may not be adjusted correctly? Does it click when it should?ORIGINAL: scam75 It could be my SciVision or the maps on the chips causing it.
