what did you do to your 944 today
- Thread starter colin944
944 man
Nearside front and rear, unfortunately.ORIGINAL: zcacogp BOTH tyres Simon? Crumbs, must have been a giant pothole ... Best of luck with the council. Potholes annoy me intensely so I hope you get satisfaction. Oli.
scam75
Well-known member
Haven't tried with both off Tom. I know it ran exactly the same with one plug off, not sure which one it was. I do know however that it won't have the right map for DPW with the plugs off as that's how the Promax chips allow you to set different maps. One plug on one off is for standard WG map 18psi, both plugs on is for DPW map 18psi. Both off is 15psi standard WG map. StuartORIGINAL: TTM What happens if you try with both shorting plugs removed?
scam75
Well-known member
Ewan
TTM
Well-known member
Sounds like it needs to be tuned. Peak boost pressure has nothing to do with low down torque and a progressive delivery. Ignition timing has. Do you know what ECU it is running?ORIGINAL: Ewan Went to JMG to drive the 3.2 with half a mind to buy it. But it's currently set at a low boost figure as the owner likes it to have more low down torque and a more progressive delivery. But it just didn't seem as quick as my car (even though it could have maybe 100 bhp more than mine after the twist of a dial or two). A little disappointing therefore.
Bob
Indi9xx
Hairyarse
Surely apologies come with pictures? [ORIGINAL: Eldavo Today I got outed for having installed a 944 Turbo in my garage without telling the forum. I'd like to apologise to the forum for letting you all down.
simdel1
Hairyarse
Copperman05
Martin Sage
