dangerousdan
I made myself some PCD adaptors / spacers today to fit some different wheels. [8D]
Sorry for the rubbish late response...work have sent me away again. [:'(] I'm not sure about the pipework and cooler. I'll have to have a proper look when I get back.ORIGINAL: robwrightSimon is the pipework and the cooler still in place also? If everything is intact then it could be quite an easy job.ORIGINAL: simdel1Cheers mate. I might take you up on that offer. I actually quite enjoy rolling around under the car[ORIGINAL: robwright Simon if you can get hold of a rack from Elliot, which I imagine you can and provided the cross member for the engine is the same then bring it to mine and we can fit it. If you need to change the cross member too then that's not really a problem. I am equipped to support the engine while it is done. I am assuming your engine still has the bracket for the power steering pump? I can't see that Pixie would have removed it as it is part of the lower balance shaft front cover IIRC. Can't see that she was that thorough as she wasn't about anything else lol [] In any case it should be doable in a weekend provided you don't mind roll around on the floor?
] The pump and reservoir are still present. Thankfully for me, it looks like the absolute minimum number of parts were removed to get the rack swapped for the (dodgy) MoT.
Will you be back for Snetterton Simon?ORIGINAL: simdel1Sorry for the rubbish late response...work have sent me away again. [:'(] I'm not sure about the pipework and cooler. I'll have to have a proper look when I get back.ORIGINAL: robwrightSimon is the pipework and the cooler still in place also? If everything is intact then it could be quite an easy job.ORIGINAL: simdel1Cheers mate. I might take you up on that offer. I actually quite enjoy rolling around under the car[ORIGINAL: robwright Simon if you can get hold of a rack from Elliot, which I imagine you can and provided the cross member for the engine is the same then bring it to mine and we can fit it. If you need to change the cross member too then that's not really a problem. I am equipped to support the engine while it is done. I am assuming your engine still has the bracket for the power steering pump? I can't see that Pixie would have removed it as it is part of the lower balance shaft front cover IIRC. Can't see that she was that thorough as she wasn't about anything else lol [] In any case it should be doable in a weekend provided you don't mind roll around on the floor?
Well, it should, it's not very tall to start with and it's right at the bottom of the dip before the start [ORIGINAL: MarkK Looks quite Squat in the first pic eh!?
