what did you do to your 944 today
- Thread starter colin944
Martin Sage
vitesse
Copperman05
Not really suiatable due to the age of the rad, seems its corroded beyond repair. Have you checked the PAS fluid? Mine groans a little when at full lock but I think its pretty normal, I think its the PAS pump straining under the pressure, not sure why it would do it on start up though. EddORIGINAL: Martin Sage Bad luck Edd thats harsh. Obviously not a Radweld job or am I showing my age? I also have a small problem that could turn out to be big. My steering groans on start up if I turn wheel left or right a small amount but is ok when under way?! Any suggestions please?
944 man
Geo will help a great deal, in fact it could be a complete solution. Your car had a power rack, and it still has the correct cross member, because Nicola knew it all... Hopefully itll all go back without too much trouble. SimonORIGINAL: simdel1 I did my first 'treasure hunt' navigation rally on thursday. Finished 6th out of 10 entrants which wasn't too bad considering how often we drove straight past the clues. We also won the award for 'hero of the event' thanks to my rather spirited departures from the manned checkpoints! Anyway,as fun as it was driving on the country lanes with excellent pace notes from my more experienced navigator, it became very clear that I need to do some work on the steering. At silverstone the steering felt weighty but with lots of feedback that encouraged me to lean on the front. Throw in some bumps and camber changes and the steering wheel was trying to rip itself from my hands and I wasn't confident to push it on the patchy damp surface. I intend to try and get a powered steering rack to put the car back to standard, which I hope will help. I might even look at getting some cookies to reduce the unprung weight. The tracking has already been done. Is there anything else I can look into?
simdel1
Thanks mate. Based on your recommendation I took it there a few months back. it was surprisingly close - I think it was only one of the rears (probably camber) that was slightly out. It'll be worth re-doing again though just to check...especially if I get a new rack in there. When I eventually find the time for that cuppa I might borrow that []ORIGINAL: Hairyarse Hi Simon. Pop over to F1 Auto Centre in P-Bro, they're a good bunch and will do a full laser geo check for free, you then pay per adjustment that needs doing. I'd guess budget £100 if it's not been done for many years. Even if you don't get anything done at least you can narrow down what the problem may be. I have to say though in my square dash, the steering did used to 'dance' about a bit on rough surfaces and the geo and everything else was spot on. May just be similar to the tramlining that we experience? One of the rear adjustments (I forget which, camber??) needs a special socket which I have and you're welcome to borrow []
*sigh* Indeed. I think I might have to have a read through the old "can you retro-fit manual steering..." threads to see what has changed and what remains.ORIGINAL: 944 man Geo will help a great deal, in fact it could be a complete solution. Your car had a power rack, and it still has the correct cross member, because Nicola knew it all...
Oh yeah, I forgot about that!ORIGINAL: A9XXC Just remember that the lower column with the 2 u/js is different too.
robwright
944 man
simdel1
Cheers mate. I might take you up on that offer. I actually quite enjoy rolling around under the car[] The pump and reservoir are still present. Thankfully for me, it looks like the absolute minimum number of parts were removed to get the rack swapped for the (dodgy) MoT.ORIGINAL: robwright Simon if you can get hold of a rack from Elliot, which I imagine you can and provided the cross member for the engine is the same then bring it to mine and we can fit it. If you need to change the cross member too then that's not really a problem. I am equipped to support the engine while it is done. I am assuming your engine still has the bracket for the power steering pump? I can't see that Pixie would have removed it as it is part of the lower balance shaft front cover IIRC. Can't see that she was that thorough as she wasn't about anything else lol [] In any case it should be doable in a weekend provided you don't mind roll around on the floor?
robwright
Very nearly mate jst a few little bits and pieces to bolt in tomorrow. I have been struggling for time lately to be honest but still no rush eh. It will be done when it's done. Or at least before it gets any fecking colder anyway []ORIGINAL: Frenchy Rob, is your car back together and running ?
944 man
I got the impression that a number of changes were made, represented as 'improvements', for which the real reason was to save money, to repair on the cheap and to sell off valuable parts (Fuchs sold and replaced with worthless Fondmetal wheels) whilst pretending otherwise. SimonORIGINAL: simdel1 Cheers mate. I might take you up on that offer. I actually quite enjoy rolling around under the car[] The pump and reservoir are still present. Thankfully for me, it looks like the absolute minimum number of parts were removed to get the rack swapped for the (dodgy) MoT.
944 man
robwright
Simon is the pipework and the cooler still in place also? If everything is intact then it could be quite an easy job.ORIGINAL: simdel1Cheers mate. I might take you up on that offer. I actually quite enjoy rolling around under the car[] The pump and reservoir are still present. Thankfully for me, it looks like the absolute minimum number of parts were removed to get the rack swapped for the (dodgy) MoT.ORIGINAL: robwright Simon if you can get hold of a rack from Elliot, which I imagine you can and provided the cross member for the engine is the same then bring it to mine and we can fit it. If you need to change the cross member too then that's not really a problem. I am equipped to support the engine while it is done. I am assuming your engine still has the bracket for the power steering pump? I can't see that Pixie would have removed it as it is part of the lower balance shaft front cover IIRC. Can't see that she was that thorough as she wasn't about anything else lol [] In any case it should be doable in a weekend provided you don't mind roll around on the floor?
Copperman05
