MartinRS2K
Thanks for that Colin, I can sleep better tonight [ORIGINAL: colin944 The blob is a big blob of the under-seal that they put on the floor .It has squeezed in through the drain hole in the sill.
Looks solid in there Oli, I intend to keep doing mine over the coming years to hopefully keep the tin worm at bay. What did you use to get right to the back corners of the sill?ORIGINAL: zcacogp I took part in the "Let's All Photograph Our Sills" game. Very grubby, but the Dynax S50 that I use is dark brown in colour which explains it. (And I have applied it thickly each year for the last four years). Doesn't look like anything to worry about in there, which I am pleased about. Oli.
All part of the service Martin.........[ORIGINAL: MartinRS2KThanks for that Colin, I can sleep better tonight [ORIGINAL: colin944 The blob is a big blob of the under-seal that they put on the floor .It has squeezed in through the drain hole in the sill.]
It does look solid, although I remain paranoid about it! I use the application tube and nozzle that came with the aerosol can of Dynax S50 and poked it both ways down the sill. There is a large black plastic plug in the back end of the sill (in the wheelarch) which can be pulled out to give good access to the back of it and I think I prodded the nozzle down to the front through one of the holes in the inner sill (pulling the carpet away to get to it.)ORIGINAL: MartinRS2K Looks solid in there Oli, I intend to keep doing mine over the coming years to hopefully keep the tin worm at bay. What did you use to get right to the back corners of the sill?
Stop it, you'll only make me more paranoid! >ContemplatesSprayingSomeMoreInThisAfternoonJustInCase< [>:] Oli.ORIGINAL: colin944 Oli love the rust protection you've got in there. The thing is though........ Do you think you got enough in????[][
