what did you do to your 944 today
- Thread starter colin944
Seems v healthy. What boost are you running, the full 1.2 bar?ORIGINAL: Eldavo Followed Martin's lead and went to Evotune in Durham to get my car set up on their dyno after installing my Promax level 2 kit
Yup, although it peaks just over 1.2bar but the drops straight back down. This is boost (solid line - left axis) against AFR (dashed line - right axis):ORIGINAL: LowtimerSeems v healthy. What boost are you running, the full 1.2 bar?ORIGINAL: Eldavo Followed Martin's lead and went to Evotune in Durham to get my car set up on their dyno after installing my Promax level 2 kit
aporschefan
My requirements were the same as yours when I needed to replace my pads earlier this year. Not the cheapest option but I opted for Ferodo DS2500 all round. (I haven't had a chance to attend a track day with them yet though.)ORIGINAL: Eldavo has anyone got any other suggestions for fast road with a bit of trackday action 2-3 times per year?
MarkK
WBray
This is something on my list to sort as it annoys me that it doesn't work. Though i do have a question hope you can answer. Do the cars sidelights need to be on for the bulb to work or should it automatically come on when the bonnet is up? CheersORIGINAL: kcbart Decided to sort out the under bonnet light. Took the bulb holder to bits and cleaned up all the contacts but still didn't work. Checked the wiring and discovered two breaks in the wire where it bends when you close the bonnet. Repaired the wire and now works as it should.
WBray
Ideal thought that was the case but thought best to double check. Thank-youORIGINAL: kcbart Hi Will, Yes, the sidelights have to be on and then the light works when you open the bonnet. Also works if you have the offside parking lights on i.e. the indicator stalk up, but not down.
edh
Agreed - Camskill are quite cheap for Mintex for the standard turbo/S2, although I'm not so sure on the medium blacks PF pads for the medium blacks are very expensive - well over £200. I wouldn't use them on a freshly sprayed road car that will see occasional trackdays because of the potential for damage to wheels and paint. Unless you really really like using a clay bar every couple of weeks..ORIGINAL: 944 man Mintex (either 1144 or 1155) or Performance Friction, if you can stand the dust.
MarkK
944 man
Good for both patterns Ed, but theyre made to measure and theres a lead time of at least a month, which they dont tell you about until after you have paid. [ORIGINAL: edhAgreed - Camskill are quite cheap for Mintex for the standard turbo/S2, although I'm not so sure on the medium blacks PF pads for the medium blacks are very expensive - well over £200. I wouldn't use them on a freshly sprayed road car that will see occasional trackdays because of the potential for damage to wheels and paint. Unless you really really like using a clay bar every couple of weeks..ORIGINAL: 944 man Mintex (either 1144 or 1155) or Performance Friction, if you can stand the dust.
