what did you do to your 944 today
- Thread starter colin944
ORIGINAL: kdp Having read Paul 190H post I decided to remove my washer bottle from the top as he suggested because it had a leak and also the headlamp washer didn't operate. I had been putting it off as I had read that it came out from the bottom and would be a bit of a struggle. It came out relatively easily although the lower mounting bolt sheared off and I found that it wasn't the bottle that leaked, but a piece of pipework had come adrift from a connector. The pipe could be accessed when the fog light was removed (Lux) and once I had connected it back together and replaced the pump the headlamp washer was operational again.
Suffolk944
Moderator
944Scott
Modified original or something completely different.ORIGINAL: Suffolk944 Dropped mine off at Promax on Saturday - it needs new brake and fuel lines plus some new rear discs - they can check for calliper plate lift at the same time just in case... Oh and as well as all that sensible stuff a new upgraded intercooler as well ! [8D]
Suffolk944
Moderator
Plan is for one of the Lindsey Racing ones - so essentially a modified original.ORIGINAL: 944ScottModified original or something completely different.ORIGINAL: Suffolk944 Dropped mine off at Promax on Saturday - it needs new brake and fuel lines plus some new rear discs - they can check for calliper plate lift at the same time just in case... Oh and as well as all that sensible stuff a new upgraded intercooler as well ! [8D]
simdel1
944Scott
Jeez the stage 2 one isn't cheap (for a reworked original}ORIGINAL: Suffolk944Plan is for one of the Lindsey Racing ones - so essentially a modified original.ORIGINAL: 944ScottModified original or something completely different.ORIGINAL: Suffolk944 Dropped mine off at Promax on Saturday - it needs new brake and fuel lines plus some new rear discs - they can check for calliper plate lift at the same time just in case... Oh and as well as all that sensible stuff a new upgraded intercooler as well ! [8D]
g944s2
