what did you do to your 944 today
- Thread starter colin944
DarrylH said:I've also upgraded the master cylinder to the 740i one a lot of people use in the states. Got to finish bleeding it all but pretty happy with how it all looks at least []
Darryl - I'm interested in the BWM master cylinder swap - does this reduce pedal travel, and is it a simple like-for-like job?
Mick
DarrylH
It is supposed to reduce the pedal travel quite a bit yeah. The 2 studs on the booster is a straight bolt up but I've had to make 3 brake lines - The 2 that go through the firewall and the one that goes to the Passenger side wheel well (RHD Car) You also need to T-piece the two front lines as there is one less port on the MC.
I've not had chance to fully try it out yet so I can't say much from experience. I will post up once I have though.
Mick
Frenchy
Wheels then sent off for refurb, I will clean and sort the brake calipers whilst the wheels are away being done.
Some interior jobs to do then it will be good to roll []
I, erm, well, you see, it's funny really, haha, looking back, easy mistake, you know how it is, welllllllll - the steering wheel boss was on upside down
Kongsodoken
StuBBerS
Had a day off today so I changed my PAS fluid, lubed the door locks, fitted dissy cap and rotor and changed the spark plugs.
Oh, and I looked at the fuel filter and thought I couldn't be bothered with that, I'll get my local Porsche specialist to do that when they have it in for the geometry.
Also removed an extremely rotten horn ready for its replacement
PSH
picture of vent in situ....
and for added interest a picture of the block awaiting the refit of it's head.....
I also took advantage of looking for an exhaust leak from the manifold at No.2 port, on close inspection I discovered a small lip where we had fitted a heli coil due to a stripped thread, it was very small but was most certainly the cause of the blowing exhaust when cold..all filed flat so should now seal correctly.
Hope to get her back together over the weekend
cheers
Pete
PSH
cheérs
Pete
PSH
PSH
oh well...live and learn as they say....
Pete
