what did you do to your 944 today
- Thread starter colin944
simdel1
Who'd have thought it, eh? Nice cold air from the front of the car is better than warm engine-bay air[ORIGINAL: HairyarseThat'll be all that lovely, fresh cold air you're now sucking in [ORIGINAL: simdel1 Drove the 944 to work yesterday with the new airbox and standard air filter. It's a little bit quieter now, but actually seems faster! There's a stretch of road near where I live where I acclerate flat out between roundabouts - I was a whole 10mph faster by the end of the strech than I have been before. I'll be getting one of those washable filters next to see if I can get a bit of extra go. []
Fat Albert
Wooohooo! My new camera has a Tilt-shift special defect, but you can achieve the same effect in photoshop by doing a graduated blur from the centre outwards and then turning up the colouration. It works best when looking down on a subject/sceneORIGINAL: 944 man MOT and one years tax.
944 man
scam75
Well-known member
.............It needs washed, and oil. Alan.ORIGINAL: scam75 I don't think I'll bother with a how much thread, people will only get upset!! Yes, the poor thing was carted along the M8 last week. I was in the van with the guy, that's the most times it's ever been overtaken on one journey! Really looking forward to getting it back. So far this is the list of things getting done: One rear wheel bearing - incumbent bearing and carrier mutilated, previous Stevie Wonder job! 2 engine mounts Rebuilt turbo with larger cold side Piston rings - old ones outside service limits (well worth doing it would seem) Big ends - Just cos we were in there, old ones were fine but only £50 for a set Oil pressure sender - old one warped Head and valves cleaned up, new valve stem seals, new guides, seats cut, couple of threads heli-coiled All top end rebuild kit gaskets inc HG plus sump gasket New intercooler - old one shrapnelated! All intake pipework cleaned Bottom end (inside and out!), pipes, hoses, ancilleries and crossmember all degreased and cleaned 55lb injectors There may be more I've forgot.............. Stuart
scam75
Well-known member
Correct. We are going full synthetic now, chuck in an oil filter too! Fcuk washing it, it will only get dirty again, might need to clear the windows though! [ORIGINAL: loc944 .............It needs washed, and oil. Alan.
Fat Albert
Wow! That would have made for an interesting moment! Glad it was found before it went fully I have covered 5,200 miles in the 968 now! (in just over 3 months)ORIGINAL: 944 man I was just reading a PS tilt shift guide... It turns out that the NS wishbone front bush hadnt failed because of oil contamination. The bolt was that loose that it was about to come out and the movement had broken the bushings. Its a rather worrying thought, but you were probably a couple of weeks, at most, away from the passenger side front wheel coming off! I havent driven it very quickly and the mileage is 231955, so I think that Ive covered less than a fortnights driving distance for you - and the bolt was barely still holding on...
MarkK
Well-known member
Copperman05
Copperman05
Rear calipers have serious plate lift and as I want (rather than need) to upgrade the front calipers to m030 I decided to buy front and rear calipers new from Exeter, also have new discs front and rear, just waiting to be fitted now. I think this will have to be the last upgrade of the year for me..[ORIGINAL: Frenchy What ya up to Ed ?
944Scott
I used some high temp silicone on mine.ORIGINAL: Copperman05 Have tried to prevent/reduce future plate lift on calipers before fitment. Applied copper grease under plates, not sure how effective will be but hopefully better than nothing.
Upgraded to m030 fronts and new rears.![]()
Super_Marv
Copperman05
My thoughts exactly! EddORIGINAL: Super_Marv M030 brakes will come in handy for you when you're descending them mountain passes!
