What did you do with your 996 today?
- Thread starter SteveAndrews
Nigelh
iandean said:Nice what parts did you visit, any issues with the current problems? Any pictures?
It obviously depends on the condition and type of wheels. If they had been straightforward not too bad alloy turbo styles then yes a good job probably can be done. But with lots of spokes and corrosion then the tyres should have come off and the valves taken out so all parts could have been accessed to do a proper job.
My wheels now look a lot better than before (see pic) but they are not perfect. I used just over 4 cans of Hycote etching primer and just over 4 cans of Hycote silver wheel paint. I also used part of a can of Hycote Adhesion promoter where copper was showing through under chrome. One tip is that the etching primer is fairly dark and this has resulted in a darker than expected silver. If I was doing it again I would put a coat of white primer on first before the silver.
Although it has been interesting to do, if they need doing again then they will go somewhere to be blasted with the tyres off and a thick layer of filler primer before getting a professional spray job. Most of the main refurbishers wouldn't touch them because of the chrome but I did find some of a more "back street" nature who would have done it although not guaranteeing that they would be as good as new.
Thunderace
Bought 996 27/05
Since then: -
Top Gear sound exhaust silencers
6 spark plugs and heat shields
Water pump, thermostat and belt
Coolant tank and 04 cap
Oil and filter change
£1923.60
Next:
Front discs, pads and MOT
Near future:
4 new coffin arms and at least one bump stop
Air conditioning pipe and condensors
Always worth trying the local locksmith, most of them do car keys and reprogramming these day just need your V5 Not sure if what you paid was good value or not. But a lot of dosh.. Love is blind.Damo911996 said:£346.82 for a new key/key fob/reprogramming as apparently i can't have my old one reprogrammed (Porsche hull).
iandean said:I take it they were HID replacements?
yes Osram nightbreaker and indicators. front drivers had stopped working but all sorted now. just need alignment as are pointing very low.
iandean said:Always worth trying the local locksmith, most of them do car keys and reprogramming these day just need your V5 Not sure if what you paid was good value or not. But a lot of dosh.. Love is blind.Damo911996 said:£346.82 for a new key/key fob/reprogramming as apparently i can't have my old one reprogrammed (Porsche hull).
Good point, will check if I ever need another one. I was told £137 to re-program current key fob but there was an issue so new ordered.
I’ve recently bought a 2003 C4S and completely smitten with it, but the spare key is a replacement and despite opening the central locking and working in the ignition, it stubbornly refuses to accept any seat position programming and insists on sending the seat all the way back and down whenever used.
Google suggests it’s a fairly common problem and there doesn’t seem to be a fix.
Hope yours doesn’t suffer the same fate.
DarrenWells said:I’d be interested to hear how you get on with the new key.
I don't have memory seats in mines, it don't have many optional extras tbh
